Fusion Encounter 10"
Max_Power
^ From a Hairdryer ^
Well I got a great deal on one of these woofers, and decided to buy it. Well, I am going to build a box this sunday if weather permits, so I need some suggestions.
Since its a 10" it the manual suggests a little ove 1 cube ported to 42hz, however I think it is on the small side, and dont want it to sound too peaky. I wanted to do 1.25 ported to 35hz.
something like this
I was planning on powering it with an Alpine MRP-M350 which puts out 350 RMS @ 2ohm if it matters.
The T/S specs are:
Max Power Rating (Watts):400
RMS Power Rating (Watts):200
Coil Height (Hvc): 22
Compliance (Cms): 341.8
Cone Area (Sd): 34.9
D.C. Coil Resistance (Re): Dual 3.5
Electrical Q (Qes): 0.412
Force Factor (Bl): 16.305
Free Air Resonance (Fs): 29.8
Frequency Response: 25Hz - 3.5kHz
Impedance (Nominal): Dual 4
Linear Excurson (Xmax): 7
Mechanical Excursion (mm): 20
Mechanical Q (Qms): 3.691
Moving Mass (Mms): 83.55
Magnet Structure (Oz): 47
Sensitivity (dB) (1W/1M): 87.7
Total Loudspeaker Q (Qts): 0.37
VAS (L): 59.13
VAS (CuFt): 2.06
perhaps I was too vague. I was looking on some recomendations for a ported box, leaning to sq for a woofer with these specs.
I know that some companies post the smallest box possible, just so people would buy it, so any suggestions?
Max_Power
Max_Power
Toledo, Ohio
Max_Power
