Do you need to fuse between extra batteries in the back? I know it is good to have a fuse from the front battery to the back battery, but if you have 2 or more batts in the rear should i fuse in between them? if the answer is yes.... what if the length between the wire between the two rear batts is around 5 feet, should i fuse within 18" of both batteries? kinda like this....
/BATTERY\_____/fuse\________________________________/fuse\_____/BATTERY\
does putting multiple fuses hurt any power that you may receive?
