fusing a distro. block
konechiwa
Jeepers
Ok, so i have knukonceptz 4awg wire running from my battery to my distro block (fused at the battery), and then at the distro block their are two runs of 8awg (about 3ft. long) running to my two amps (one of them being brand new). They both have fuses on the amps, but i was wondering, should i put a fuse in both 8awg wire runs? Should i fuse them? Would it matter, because the amp itself has a fuse...
My distro block also came from knukonceptz, and has no fuse. My question is this:
Should i fuse the outputs of from the distro block, so that their is another fuse between distro and the amp itself?
Thanks
do u have fuse spots on ur power distro? most power distor block comes with fuse holders in em if ur have em fusem up. one fuse = the total of amps ont he fuses on the amp and the other doing the same. the main fuse at the battery will be the sum of ur total load.
konechiwa
Jeepers
konechiwa
Seattle, WA
konechiwa
