Fusebox???
AK SloPok
Pul out your users manual or fuse box cover. There should be a diagram on or in one of those which will show you the correct fuse to pull. Pull the fuse and make sure it is/not blown. Then check some other fuses.
If power is not getting to the fuse box you may have blown a fusable link to it, probably under the hood area... may need a service manual.
Okay, there may be a master fuse for the accessory circuit in a different fuse box (possibly under the hood). If not, there might be a problem with the ignition switch. There aren't too many other accessories that share the same key-switch circuit with the radio; do your windshield wipers work?
AK SloPok
AK SloPok
Anchorage, AK
KaeZoo
