If you place two of the blue guns 1st, max out their damage (dont touch the range) follow it up by placing a rocket launcher close to it. Basically in a triangle form. If all 3 glow yellow, then the formation is correct. Once the rocker launcher is maxxed, you have nukes.what the **** are nukes and where can i get them?
They'll be the big bombs going off... cant miss it. Start placing the 100% damage multipliers around them and keep adding. A decent nuke setup will get you past wave 500 quite easily. After that, the way you set them up, etc will start to come into play.
Personally I ended up using taser rockets to slow them down and allow the nukes to concentrate fire on one area. Worked pretty well until mid 500s. Perhaps ill try again, still havnt got the hang of laser chains.
