full MSD ignition system distibutor, 6al box, wires, holley 600carb eletric choke NEW
slapmaster
http://www.msdignition.com/forum/archive/index.php/index.php?t-8030.html
11-28-2006, 09:06 AM
The E-Curve Distributor will trigger any of our MSD Capacitive Discharge Ignitions. To will see an improvement over the E-Curve once you add a CD Ignition. If this is a street car, I would recommend a 6AL PN 6420. The gear that comes on that distributor is an iron gear. To match up to the roller cam in that engine, I would recommend using a steel gear, PN 85833.
Straight from MSD tech off another forum.
Ok then, i might pick it up. Can i use it with stock dizzy and coil or should i get a new coil if i grab this up ??
just take the 6al part from that quote the rest is irrelevant to you. You can use stock dizzy. you can also use stock coil if you have to but a blaster 2 coil would be better.
slapmaster
slapmaster
mobile al
slapmaster
