FT: Sundown 1500 (like 30 minutes play time)
Twistid
i baught a sundown brand new ... installed it ... listend to it for like 30 minutes, then took it out because my electrical is to wimpy for it...
although it sounds dumb i want a bigger amp... orion 2500 or similar... since im already upgrading my electrical i might as well upgrade amp's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
comes with everything it comes with brand new, except for stickers... i got no stickers with it... i dunno whats up with that cus i wanted one of those banner sundown stickers but oh well //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
They don't generally come with stickers. Many of my team guys have them and a couple guys bought them.
Your reasoning doesn't make alot of sense...
You electrical system is too weak for a 1500 watt amp... you upgrade it to handle that... then put in a larger amp at which point your electrical system will probably be too weak for it even with the upgrades you made unless you go all out. For a 2500 watt amp expect 280 - 300 amps of current draw at 12.8 volts to actually see 2500 watts from it... that is pressing the limit of a single run of 1/0 wire (without dropping voltage). Also, does you subwoofer setup need that much power? In a daily application your actual SPL gain is going to be very small, if any, due to power compression. If this is for competition then it might be worth it.
Might want to think about it before you jump into yet a larger amplifier. Quite possibly one with no warranty at that.
Twistid
Twistid
in a space out of sound
bdawson72
