Sold FS: VERY RARE MMATS SQ4150 4 channel 4x150 @ 4 ohm
newtitan
Hey all I am swithching again --lol
so anyway I have a two week old MMATS SQ4150
4 channel amp
the specs on it
are 4x150 @ 4 ohm, 300x2@ 4 ohm bridges
I was running it active on my seas tweets, and XXX mids
and it is VERY CLEAN,and very lively
I am the only owner, first user!!!
I need to get a amp that has a quieter fan since my amps are stored inside my truck cabin
it has dual gains, high end toshiba outputs (if you ask MMats they will tell you these are the best outputs available on the market --their words not mine)
Id guess the actual power at about 175x4, but thats just based upon using so many amps
if I had a trunk there would be no way Id ever sell this, but I dont --lol
nice small foorprint,and it is the newer model with the flip up top so you can see the internals
here is the webpage
http://www.mmatsproaudio.com/sqamps.htm
there are no scrathces on the amp at all!!!
as the finish is really nice and I was really careful
I have all the orginal packing
my feedback
ebay: bigpoppatitan
heatware: amd4life
Ill post some pics when I get hoen timight (as im at work )
external and internals
email with any ???'s
oh yeah $400 shipped
internal shot
wow. this amp must be a freckin monster. 150x4@4?! ****.
400 is a fair price i suppose.
why dont you switch the fan out for a quieter one? or mod it so it runs at 7v? (a little resistor inline with the fan's ground wire will do this)
1) the amp is rated at 150x4 @ 4 ohm, and I was running the rear channels at 2 ohm stereo for my mids (Re XXX mids 2 ohm)
I called MMats and they told me that their is some sort of internal circuitry that allows for it to keep the same fidelity and power even if you lower the impedance to 2 ohm stereo
most amps loose some SQ (but gain more power) once you run them down to 2 ohm
bridged the lowest it will go is 4 ohm, any lower than that mmats did not recommend
so 300x2 @ 4ohm bridged good enoguh for most subwoofers--lol
although this is a really clean amp that would almost be a waste unless you are running ahigh SQ xbl2 sub or something or Arc or IDv3
2) there is no onboard fuse, you have to run a inline fuse at the distro block
I use a 80A, but Mmats told me 60A would be fine since its rather effiecient--doenst draw alot of current at all
never benched it, but my truck is very sensitive to current hungry amps (since I run all A/B power), anything that drawas a ton of idle amps causes alternator noise, and with this amp I dont get any
3) as far as the fan goes, have any idea how to do that?? as I have changed computer internal fans, but never a amplifier, figured it be too difficult to risk the damage to the PCB
4) and oh its actually rather small in size //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif, if you look other amps that do the rated power (which arent very many) this one is the smallest hence why I bought it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif and all I knwo is that MMATs stuff is waaay expensive
18.375 x 11.5 x 2.125
L x W x H
anyway I get off in a few so Ill have pics up then
more pics added for those who were interested
it now out of my truck in the original box
no scratches, no marks on the mounting tabs, no bent fins, absolutley MINT!!! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
newtitan
newtitan
CALI
newtitan
