Sold FS: Two Soundstream 12" Tarantual T4 Series Subwoofers!
mcquesten
TN
I bought 4 of these back when I had my SUV, but now I have a single cab truck so 2 is all I can fit.
They have had VERY little use. The two I have in my truck right now are very loud, and the box does't even fit them right at all because of the limited space.
.RMS POWER (WATTS) : 900
1800 WATTS PEAK POWER HANDLING
VOICE COIL DIAMETERS (INCHES) : 3.0
MAGNET WEIGHT (Oz.) : 200
FREQ. RESPONSE (Hz) : 25 - 1.7k
Fs (Hz) : 36.5
Qes: 0.414
Qms: 3.584
Qts: 0.371
Vas (Ft3) : 1.03/29.27 liters
Xmax (INCHES) 0.63
SPL (dB) : 89
HOLE SIZE (INCHES) : 11.25
WOOFER DEPTH (INCHES) : 6.1
RECOMMENDED ENCLOSURE (Ft3) : Ported 2.2
RECOMMENDED ENCLOSURE TYPE : Vented
AEROPORT DEMENSIONS (INCHES): 4 x 7.5(1)
Cast Aluminum Basket
Dual 4-Layer, 1-ohm Voice Coils
Cloth Laminated Paper Cone with MD6 coating
Stone Gray Finish with Diamond Cut Edge
Hi Arc, High Excursion Surround
Chrome Plated Back-plate
Low Carbon Top and Pole Piece
Triple Stacked Magnet Structure
Vented and Extended Pole Piece
Black Progressive Roll CONEX Spider
Woven Tinsel Leads
Gold-Plated Binding Posts
BAEISV Hybrid Voice Coil Former
C- Lock Rubber Gasket
Rubber Magnet Cover
$300 for both.
Yes they can get very loud. When I had the SUV I had two of them in a nice ported box that fit them really well, and they were very loud. When I had all 4 hooked up it was gettin crazy.
I miss my suv trucks just don't give you much room to play with. //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
I can fit ~12ft^3 in mine below the window line once I take the back seat out...anywho, bump for some underrated subs. I might have to tell a friend of mine about these.
Mine is just a single cab though, so no room at all. But yea thanks tell your friend.
mcquesten
mcquesten
TN
mcquesten
