FS: Two (2) Elemental Designs 11Kv.2 10" Subwoofers
loknload
SOLD! Two (2) Elemental Designs 11Kv.2 10" Dual 2 Ohm Voicecoil Subwoofers
I bought them new and have had them for about 5 years. They were in .6 cubic feet each behind the back seat of my Tacoma double cab and hit hard with 400 watts to them. Pretty much perfect shape with original boxes. Will only sell as a pair.
Specs:
11Kv.2 Subwoofer
Sealed Enclosure Yes
Vented Enclosure Yes
Infinite Baffle Yes
Box Size Suggestions Outline
11Kv.2 Subwoofer
Sealed ( small ) 0.3ft³
Sealed ( ideal ) 0.5ft³
Sealed ( large ) 0.6ft³
Vented ( ideal ) 1.0ft³ Tuned to 30Hz
Vented ( DDLoud) 1.2ft³ Tuned to 35Hz
Frequency Response Information
11Kv.2 Reccommended 0.5cF Sealed Enclosure FR Information
Frequency Response : 10 - 100Hz @ less than .5dB Variation
Average SPL in 0.5cF Sealed Enclosure : 120.62 dB
Peak SPL Out in 0.5cF Sealed Enclosure : 134.0 dB @ 55Hz
11Kv.2 Reccommended 1.0cF Vented Enclosure Tuned to 30Hz FR Information
Average SPL in 1.0cF Vented @ 30Hz Enclosure : 121.14 dB
Peak SPL Out in 1.0cF Vented @ 30Hz Enclosure : 136.3 dB @ 54Hz
Specifications
Qts: .28
Qes: .31
Qms: 2.7
Fs: 24.80Hz
Re: 7.0
Vas: 66L
Mms: 116.0g
Bl: 19.00T*m
SPL: 87.1dB
Sd: 350cm²
Xmax: 15.1mm
Voice Coil: 50.0mm
Magnet Width: 5.700"
Cutout Diameter: 9.125"
Mounting Depth: 5.000"
Weight: 13lb
Total Height: 5.450"
Displacement: .05 ft³
Outside Diameter: 10.250"
$100 + Shipping
Buyer to pay actual insured shipping
Your ASPM1500 looks like it will do 1000 watts into a 2 ohm load. I was giving them 800 at 2 ohms with a Rubicon RUB1.1000D that the gain was set correctly with a multi-meter and they loved it but I was running them in .6 cubic feet each sealed. The specs say that they are 300 RMS/600 peak but I think that's a little under rated. I'm pretty much a rock and SQ type of listener and don't like boomy bass so they worked well for me. The specs are listed above and they can be put in a 1.0 cubic foot enclosure tuned to 30 hz but I've never heard them ported and I'm not familiar with your OA15 or your install to give you any comparison.
What's the shipping total??
I'm most likely gonna buy these!
They weigh 13 pounds each and they'd go out parcel post and most likely be around $17-$18 each to ship to Colorado with insurance and delivery confirmation, unless somebody knows of a better way to ship.
Still here. Trades I'm interested would be an Audio Control LC6i or any other higher end (at least) 6 channel line output converter with a line driver built in, subs with less than 5" mounting depth such as MB Quart RLP304, Alpine SWR-T12, SI BM MKIII, Polk Audio MM1040
2nd opinion on these woofers people?
I've been recommended eD amps before, so I know it's a good company!
I just wanna do like 135-140dB at 30hz clean with these puppies ported @ 30hz on 800 watts! Possible?
loknload
loknload
Woodburn, OR
loknload
