Sold FS: Truebass 8
domeski
the domers
Up for sale is a Truebass Solution 8" sub dual 4. Bought it a while ago but only tried it out for about 10 minutes or so. Everything is working fine, has just been sitting in my room collecting some dust. 60 plus shipping.
basically all i have is this from another post
Diameter: 8.375” (213mm)
Mounting Hole: 7.25” (184mm)
Depth: 5.625” (143mm)
Weight: 10 lbs (4.5 kg)
Basket: 4 leg Cast Venezuela
Screw Pattern: Standard 8 Hole
Cone: Pulp Base with Poly Dish
Surround: 1.125” (29mm) Foam Half Roll
Spider: 6” (152mm) Phenol Treated Cloth
Arrangement: 5 roll Linear
Voice Coil: (2) 3.7 ohm DCR Round Copper
Diameter: 2” (51mm)
Magnet: (2) 5.25”x.75” (133x19mm) Slugs
Top Plate: 5”x.375” (127x9.5mm)
Back Plate: 5”x.375” (108x9.5mm)
Back Plate Bump Out: None
I gave it 500watts and was fine and suppose to take 1000watt burps. Decent sub i guess, only selling it because I went with DD1008's a while back
I'll trade you a pair of brand new PG zeropoint 5.25" midbass/midrange drivers //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif 3mm xmax don't really know the other specs... when my truck gets fixed I'll be able to listen to the used set I bought. I have two sets but want other stuff..
how does it compare in your opinion to the DD 8"s?
domeski
the domers
domeski
Costa Mesa, CA
HawaiianBassHed
