I am going to sell my brand new TC-2000 sub. I am asking $225 + $25 Shipping for this Massive Driver . Ive been waiting to install this for HT system but I really need the money . This is a 4 Ohm SVC .
Key Features
• 100 Newtons2/watt Motor Force
• 800 Watts Sustained Power
• 3" Anodized Aluminum Voice Coil
• Single Dish Aluminum Cone
• 1" Wide NBR Surround
• 190 Ounce Magnet Structure
• 28mm XMax
• 10" Diameter Suspension System
• Custom Cast Aluminum Frame
• Quick-Detach Top Assembly
Specifications
What makes the TC-2000 The New Standard for a high performance 500 dollar driver for only 325 dollars? See what’s inside that makes it the best solution for those who are ready to take on a reference level of bass!
Advanced FEA Motor System
• Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
• 190oz top grade magnet structure
• Anti-flux modulation copper shorting ring to lower distortion
• Low carbon steel used for the gap plate and t-yoke
• Large pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
• Dual high excursion 10" linear roll poly-cotton spiders
• Intergraded woven leads to prevent lead-slap
• 3" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
• Extra spacing in-between spiders for lateral stability
• Single or dual 3.1Ω (4 ohm nominal) voice coil configuration
• Lightweight brushed and powder coated aluminum cone
• 1" wide long throw, highly durable NBR surround
• High quality thermal flexible epoxies to ensure longevity
Patented custom cast aluminum frame
• Extra clearance under the suspension for dynamic high excursions
• Wide spider landings for higher than average throw
• Patented detachable method for easy and fast and recones or repairs
• Durable high gloss black powder coat and chrome vc mesh guards
Performance
• Effective motor force of 98 Newtons2 per watt (BL2/Re)
• 800 watts continuous power (2500 watts peak)
• 28mm BL XMax (voice coil, one-way)
• 41mm XMech (mechanically limited, one-way)
Key Features
• 28mm XMax
Specifications
Performance
