FS: Super Cheap big box
Boomsday
My House
FS: 4.95 gross, (without know what subs are going to go in cant calculate net) 31hz
35.75w 20d 15H was going to be for a guy but he is switch vehicles and doesnt need it
Would work perfect for a pair of 12s or a single 15. The top is not attached just in case i need to add more bracing
Looking to get $85shipped. I can paint it with latex whatever color you would like for $13 or even carpet it (prices vary depending on color)
Thats a 15" basket and xsv2 motor btw so you can see size
You do some nice work man. And that is a hell of a deal! $85 wouldn't even cover the cost of wood (Unless you use cheap ****, which one can obviously tell is not the case)
Thanks just figured somebody could use it
Out of curiosity, what wood do you normally use?
Birch 7ply sometimes 5ply (depending on power and if trying to keep cost down) just make sure you brace no matter what wood you use and you will be fine
I'll likely go Birch with my next box due to weight over MDF (My 4 Cube box for SA-12s was a ***** to get into my truck). I've used Blondewood and Aruco on lower power stuff, cheap and its about 6 or 7 ply.
The tweeter has to be crossed over somehow. Doesn't matter if it occurs at the HU, the amp or passively.
906
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
Starting from scratch don't have an amp yet gonna wait till I make a decision on which subs right now I'm just trying to settle on which subs I'm...
Boomsday
Boomsday
My House
rickmandick
    May 20, 2024
    May 20, 2024
