1. Product:
Sundown Audio SAZ-1500D
2. Specs:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
Rated power output ----RMS power, 2 ohm linkable/dual mono
1500W x 1CH----RMS power, 2 ohm mono800W x 1CH----RMS power, 4 ohm mono
400W x 1CHSignal to Noise Ratio>90dBLow pass frequency crossover35Hz~300HzSubsonic filter10Hz~60HzBass boost @ 45Hz0~18dBPhase shift control0~180 degreeFrequency response10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm
3. Description/Condition:
Amp is in really good condition. There are a few light scrathes but nothing major and functions 100%. Everybody knows these amps put out more than rated power and can be run daily at .5 ohm.
4. Price: :
$300 Shipped with tracking OBO
PM me for quickest response
Only trades I would be looking for would be old school Fosgate 1500bd, 1501bd or Power HX2 motors
5. Pictures:
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). [/i]
2. Specs:
Variable Bass Boost
1 Ohm Stability
4. Price: :
5. Pictures:
