Sold Fs: Sundown SAZ-1500D
DarkScorpion
1. Product:
Newer heatsink style Sundown SAZ-1500D
2. Specs:
Off of Sundown's website:
SPECIFICATIONS:
----RMS power, 1 ohm mono 1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono 400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
3. Description/Condition:
9/10 Cosmetic
10/10 Mechanical
Only a few weeks old
The amp is in overall great condition. There are no major scratches on the surface, only a slight scuff on the top that I couldn't even capture with my camera; it's hardly noticeable. There is a little scuffing on the very edge of the amp where the power and speaker inputs are (it's on the edge itself, not the surface). There is slight scratching around the mounting feet from normal wear - nothing that will be visible once screws are mounted down. The back of the amp has a few scratches, but once again, it's nothing major. I have included pictures of the internals to show that nothing is burnt or blown. Everything works flawlessly.
4. Price: :
Sold
5. Pictures:
Paypal only. I do not have any of the original accessories nor the original box.
DarkScorpion
DarkScorpion
Austin, Texas
DarkScorpion
