FS: Sundown SAX 125.2
$LICK CALIFA$
Sundown SAX 125.2
Got this on a trade, I have no use for it so it has to go.
Used, excellent condition. I tested it on arrival and everything works and sounds great (pic 1)
9.5/10 cosmetically and 10/10 function
Comes with original box
2/1 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
12dB Octave Electronic Crossover Slope
Variable Subsonic Filter
High Pass Filter Variable with x 10 Range Selectable Switch
Low Pass Filter Variable with x 10 Range Selectable Switch
HPF/FULL/LPF Selectable Switch
Variable Bass Boost Control
Variable Bass-Boost Frequency Control
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Rated power output
----RMS power, 4 ohm stereo
125W x 2CH
----RMS power, 2 ohm stereo
200W x 2CH
----RMS power, 4 ohm bridged
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 50Hz ~ 5KHz
High Pass Crossover 30Hz ~ 3KHz
Variable Subsonic Filter 10Hz to 500Hz
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 20A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 340(L)mm
$150+ Shipping - No Trades
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
