Sold FS:Sundown Amps, SI MAG, Kinetic HC600.Everything must go!
no need for that... some people might actually use it for a sub amp. No every sub wants 1000+rms. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
thats why i was asking...if it was made to be a sub amp then i wouldnt want it to power my front stage
It can be used as both, I think its a class a/b tho, not a class D. Class D = mono = mainly sub amps.
Class D amps have less amp draw, but they're normally in the bigger wattage area.
That sundown would be perfect for a front stage, I'm getting one to power my rainbows //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes I used the 100.2 on the front stage and the 1500d on the sub.....
SAZ1500d specs:
1500 x 1 watts @ 1 ohm
800 x 1 watts @ 2 ohms
400 x 1 watts @ 4 ohms
0.2v - 6v adjustable input sensitivity
10 Hz - 350 Hz Frequency Response
>90 dB dB S/N Ratio
4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
Linkable to another SAZ-1500D for up to 3000 watts @ 2 ohms
35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
10 Hz - 60 Hz adjustable 24dB Subsonic Filter
0 - 180 degree adjustable phase shift
0 - 18 dB adjustable bass boost with 45 Hz center frequency
Wired Remote Control unit included
4x 40 Amp Internal Fuses
17" L x 9" W x 2" H
$599 US Dollars - MSRP
SAX100.2 specs:
100 x 2 watts @ 4 ohms
200 x 2 watts @ 2 ohms
Damping Factor > 350 @ 4 Ohms
10 Hz - 40,000 Hz Frequency Response
Channel Separations: 75 dB
> 90 dB S/N Ratio
Selectable HP / LP / FULL crossover
35 Hz - 300 Hz adjustable 18dB Low-Pass Crossover
75 Hz - 2,000 Hz adjustable 18dB High-Pass Crossover
3x 20 Amp Internal Fuses
13 3/8" L x 9" W x 2" H
$299 US Dollars - MSRP
angrytrucker78
angrytrucker78
St Louis, MO
angrytrucker78
