Sold fs Sundown 50.4 w/warranty
RetroAudioinc
Custom Car Audio Decals
1. Product:
Sundown 50.4
2. Specs:
The SAX-50.4 was designed as a "little brother" to the SAX-100.4 for those that do not need as much power and/or have limited space to work with. The SAX-50.4 matches very well with the SAZ-1000D as a complete amplification system.
The same crossover features as the SAX-100.4 "C" revision are included.
SPECIFICATIONS:
  • 4/3/2 Channel Bridgeable Class-AB Amplifier
  • MOSFET PWM Power Supply
  • Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
  • 12dB Octave Electronic Crossover Slope
  • Variable Subsonic Filter
  • Independent 1/2 Channel High Pass Filter Variable with x 10 Range Selectable Switch
  • Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
  • Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
  • Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
  • Independent 1/2 and 3/4 Channel Bass Boost Variable Control
  • Variable Bass-Boost Frequency Control
  • Variable Input Level Control
  • Input Sensitivity : 200mV ~ 6V
  • Subsonic Filter : 10Hz ~ 500Hz
  • Signal Input and Line Out RCA Connectors
  • Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
  • Tested Voltage & THD: 14.4V & Less than 0.05% THD
  • Operating Voltage : DC10V~16V Power Input
  • Wired Remote Controller
  • MSRP $349 USD
Rated power output ----RMS power, 4 ohm stereo
50W x 4CH ----RMS power, 2 ohm stereo
80W x 4CH ----RMS power, 4 ohm bridged
160W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH3&4) High Pass Crossover
50Hz~5KHz (CH1&2)
50Hz~500Hz (CH3&4) Variable Subsonic Filter 10Hz to 500Hz Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) THD@RMS Watts
3. Description/Condition:
Used in very good condition sounds great have org box as well. Still under warranty.
4. Price: :
$190 shipped with org box, manual and bass knob.
5. Pictures:
just bought a laptop from BB cant afford shia now //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
got any 0 gauage anl waterproof fuse holders for my second battery? I keep getting this hillbilly by me saying I dont need one as long as my front bat is fused //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
RetroAudioinc
RetroAudioinc
Indianapolis, IN
DS Autosports
