Sold FS: SoundSplinter, Rythmik, Kicker, Sirius...etc.
ngsm13
BSEE
Soundsplinter Rl-i 12": MINT condition, single 4ohm. http://www.soundsplinter.com NO LONGER available. $170 shipped to the 48.
Rythmik Audio Plate 250w amplifier: Similar to PE's great plate amp, but IMPROVED upon by rythmik. NO noise from this, even under full-tilt operation. Little underrated, will give 250-300rms @4ohm. (perfect match for rl-i12 in home ported...) $130 shipped.
Kicker KX600.4:
Used, 2003 model.
4 x 75 rms @4ohm
4 x 150 rms @2ohm
2 x 300rms @4ohm bridged
Great amplifier for active setup utilizing 2ohm mids. Or great for a pair of 4ohm subwoofers...or single dual4ohm subwoofer.
Go for around $160 shipped on ebay (refurbs). I'll sell or $145 shipped.
Alpine Sirius direct connect box. Incudes ALL piece, tuner box, antenna, wiring, screws, etc... In original box. Opened, and taken out...planned on using it but decided not to. Go for around $75-95 shipped on ebay. I'll sell for $60 shipped.
NO TRADES! NO OTHER OFFERS HERE. Any questions or offers, PM ME! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Thanks,
NG
Ok sounds like a plan bro, also I would like to talk to you about this unit as far as the options on it crossover points, speaker connections, rca ins and outs, options on how you hook it up.
It has hi-level AND low level inputs (and outputs). I has a fully variable phase knob, as well as fully variable xover knob, and obviously a level knob. If you use speaker-level inputs, the speakers are highpassed at 125hz @ a 6dB/oct slope...and you can adjust the sub xover however you want. You can set it to on, off, or auto-on. Great unit.
NG
Ok I got dibs on the plate amp then...also you can run a sub and speaks off it correct? If so does that split the power or how does that work?
No, you can't RUN the speakers off it...it doesn't power the speakers. If you don't have a subwoofer RCA output on your receiver, it allows you to get a SIGNAL from the speaker level inputs, the speakers are still powered by the source receiver though.
NG
Mr.Loki - It's cool....Don't get your pants in a bunch. I just ASSUMED b/c of your question:
"also you can run a sub and speaks off it correct? If so does that split the power or how does that work?"
you didn't sound so sure... You know what they say when you ASSUME :)
NSGM13,
LMK if Mr.Loki takes it or not. Thanks.
ngsm13
BSEE
ngsm13
Cincinnati, OH
ngsm13
