Sold FS: Soundgate "XR4"- Line Output Converter
krisfnbz
Turns out My friend did not need this part in his car. We hooked it up once, and realized that it wasnt going to work in his car and took it out. Comes with everything LNIB, as pictured below.
$60 shipped takes it. Plenty of refs on this site.
Soundgate's top selling device, the Soundgate XR4 is an adjustable, high performance, dual purpose, 4-channel device which functions as a headunit replacement interface (replacing the OEM4A) or as a line output converter (replacing the LOCVH4A) simply by switching the XR4 output wiring harnesses included with the device. The XR4 features complete isolation, low source impedance, high signal levels, flat and extended frequency response and most importantly....no noise!! Handles up to 85 watts per channel.
As a Headunit Replacement Interface....
The XR4 is designed to seamlessly integrate new source units into virtually all factory amplified systems. The universal wiring pigtails will connect directly to the wiring harness supplied with your new headunit and any factory-match wiring harness available at most car audio dealers. And with independent gain adjustments for each channel, and high power handling capabilities, it will easily handle any of today's after-market headunits, including high-power MOSFET's.
As a Line Output Converter....
Connect the input pigtail leads on the XR4 to the speaker level outputs of your existing factory or after-market headunit, and, using the RCA output pigtail of the XR4, plug in the RCA cables from your new amplifier to the XR4, adjust the gain and you are on your way to noise-free, high fidelity sound.
krisfnbz
krisfnbz
Frederick MD
krisfnbz
