FS: Sony Dream Home Theater System - 270.00 shipped
NathanMc
Resident Stoner
I'm selling my surround sound dream system, simply because I don't use it that much at all. The thing is awesome and works great! It's a 5 disc CD/DVD player, 5.1 surround sound, sounds badass. Retails for quite a bit. Can get pics on request.
I do have paypal. and I just might be open to trades on it too..lemme know what you got.
The information is below..
Sony's DAV-FX10 home theater system gives you everything you need to turn your living room your own personal cinema befitting of today's demanding surround sound Hollywood blockbusters. This Sony Dream System features a 5-disc progressive scan DVD player/changer that's compatible with SACD discs and has an integrated receiver that provides 1,000 watts of total system power output. It also comes with a six-speaker, 5.1 surround sound system (one subwoofer with 7.9-inch driver, one center channel, two front satellites, and two rear satellites), and offers Dolby Digital, DTS, and Pro Logic II processing for surround sound from DVD, VHS, and stereo sources.
The slot-loading 5-disc DVD player/changer is compatible with a wide range of disc formats, including standard music CDs, SACDs, DVD-R/RW, DVD R/RW, CD-R/RW, as well as MP3 audio files and JPEG image files. Other features include a 12-bit, 108 MHz DAC (digital to analog converter) and three play modes (shuffle, program, repeat). Sony's Precision Cinema Progressive detects image changes at the pixel level versus other types that detect image changes at the scan line level. Separate algorithms are used to process the moving and still parts of an image to achieve sharper backgrounds and moving objects that are free from motion artifacts.
This system also offers SACD (Super Audio Compact Disc) playback for high-resolution audio that carries a one-bit Direct Stream Digital signal, recorded at a phenomenal 2.8224 MHz sampling rate. SACD supports both stereo and multi-channel music reproduction.
This set of compact speakers are perfect for rooms with little space to spare. They're designed using precision crossover assemblies to ensure that all speakers blend and recreate a seamless soundstage. TodayÕs discrete digital surround formats are able to reproduce the same sound throughout every speaker. If a variance in speaker drivers, crossover settings, or driver material occurs from one speaker to the next, the pitch and surround illusion can suffer. Sony speakers are designed using matching driver compliments and crossovers to ensure perfect blending.
The integrated receiver/amplifier features a 6-channel amplifier (143 watts x 5, plus 285 watts for subwoofer), sleep timer, Bass Boost functionality, and AM/FM digital tuner with 30 total available presets. It provides the following connections:
* Composite Video In: 2
* Composite Video Out: 1
* S-Video Out: 1
* Component Video Out: 1 (Y/Pb/Pr)
* Analog Audio Input: 1 optical and 1 coaxial
* Headphone: 1
all I have right now are the following pics
http://www.marijuanamusic.net/NathanMc/1.jpg
http://www.marijuanamusic.net/NathanMc/3.jpg
I'll take more tonight of the complete set up, you can on the 2nd pic the two connector things missing that I lost..since I didn't use the rear channels. I did however rig it up with eletrical tape and normal speaker wire..which I still have the entire roll I will give to the buyer, and it worked great and you couldn't see it anyway.
NathanMc
Resident Stoner
NathanMc
Eastern NC
NathanMc
