Sold FS Sony 4/3 Ch amp XM-ZR604
919motoring
917
nc
It works litlle scratched up $50.00 shipped (lower 48) PM ME
SPECS:
150W x 2 (at 2 Ohms) + 300W x1 (at 4 Ohms) Max Power
60W x 2 RMS into 4 Ohms
65W x 4 RMS into 2 Ohms
High Level Sensing Power On
80Hz High Pass filter with -12dB/Octave Slope
80Hz Low Pass Filter with -18dB/Octave Slope
MOSFET Power Supply
RCA & speaker level inputs
Line level thru-put
CEA-2006 Power Compliant
Output Power:
CEA Rating: 60W x 4
DIN 45500 Rating (@ 14 V, THD 0.5 %)
4 ohm: 4 x 60W
2 ohm: 4 x 65W
Rated/THD (@ 14.4 V, 20 Hz - 20 kHz)
4 ohm: 4 x 60W / 1.0% (14.4V, 20 - 20kHz)
2 ohm: 4 x 65W / 0.1% (14.4V, 20 - 20kHz)
Maximum (@ 14.4 V)
4 ohm: 4 x 110W
2 ohm: 4 x 150W
Input:
Low Pass Filter: 80Hz
LPF Roll Off Rate: -18dB/oct
Subsonic High Pass Filter :: 80Hz
Input sensitivity: 0.3 - 6Volts
Output:
Frequency Response: 5Hz - 50kHz
Tolerance: +0 / -3dB
Total Harmonic Distortion (@1 kHz): 0.005%
CEA SN Ratio: 97dB
Min Load Impedance/Ch: 2 ohm
919motoring
919motoring
nc
919motoring
