Rockford t8004
50x4 @ 4 ohms, 100x4 @ 2 ohms, 200x4 @ 1 ohm, 400x2 @ 2 ohms, variable 40-4kHz HP/LP selectable 12dB/oct Butterworth, 24dB/oct Linkwitz-Riley crossover, 10x crossover switch, 2/4 channel switch, 12dB/Octave Infrasonic filter @ 27Hz, RCA inputs, independent RCA outputs with 12dB/Octave HP/AP/LP Butterworth crossover, cast aluminum heatsink, military spec PCB, 1/0 AWG power/ground connectors with built in ANL fusing, Intelligent thermal management, and variable 35-70Hz remote ParaPunch.
Used. 6/10 cosmetics. Has scratches nicks and dents. Has end cover. Also one screw is broken in the terminal. Amp works great
175 shipped
Fedex
Rockford t8004
175 shipped
Fedex
