Sold FS: -= RE - Massive - DLS - Alpine - Beyond Audio - Marathon - HIGH END GEAR =-
Phiber Optik
I have several items stored in my stereo closet that I might as well try to sell instead of collecting dust.
Massive Audio CA-200 (now Discontinued)
This is Massive's Highest level A/B SQ amp but a year or 2 ago they decided to discontinue it for the cheaper P series, It's quite big at 19.5" long, This is the second generation with internal fusing, and the great protection circuitry, This is a 2 channel amp producing over 300RMS x2 @ 4ohm, and 1000rms x1 @ 2ohm @ 12.5 volts, but at 1ohm it will produce much more. Here are my pics from ROE amp guts.
As you can see this amp has a serious power supply section comprable to amps of much higher rated power levels.
The amplifiers condition hasn't changed, still like new in box!
$500 OBO
Massive Audio PA 25.4
Here is a little 4 channel A/B class does 75w RMS x 4 @ 4ohm, bridgable, stable at 2ohm mono, for around 325 rms x 2 @ 2ohm, good little amp with nice protection circuitry, in good condition with all boxes and paperwork
$250 OBO
Marathon 6150 (Discontinued)
This is the company that started the buzz, and later became known as Massive Audio,
I have one of there very rare (I have only seen 1 in my life including on the internet, and I own it) 6 channel A/B 6150's, it's rated at 6 x 60w RMS @ 4ohm @ 12.5v, but this amp will bridge down low to produce much more power! as with all unregulated power supplies with the car running you are going to see 30% more power. This is another larger amp comming in at 18 1/8" long with a beautiful thick aluminum heatsync.
This amp is also in like new condition.
$500 OBO
DLS Ultimate A3
I've got a A3 in very good condition with the original boxes and paperwork, it's a great highly regarded super clean A/B class 2 channel amp
$350 OBO
Massive Audio DMX 15" N.I.B.
This is a great all around sub, this is the second generation, but not a Stage 2 sub, dual 2ohm, still new in the box! gets very loud in ported enclosures, I have a twin DMX that I used to do a drop in test with my XXX 15" (with a 31hz 4.0ft^3 box made for the XXX) and I honestly couldn't tell the difference in SQ or Loudness! I have a set of 12"s that I paid over $600 EACH for!
(12" pictured)
I'm willing to sacrifice this for $300
Resonant Engineering XXX 6.5" (Originals) N.I.B.
I don't think these need much explanation, 7" mid woofers, XBL^2 motor 13mm one way Xmax, single 2ohm coil, never used, still new in the box from RE with the plastic covers to protect the cone and surround.
Make an offer, I'm not 100% sure if I want to sell these or not...
Beyond Audio Inhuman 18"
Beyond Audio Inhuman 18" dual 2ohm coils, triple soft spider, triple stacked magnet, copper coils, 2400w RMS power handling
Quotes from other CA.com members about this sub;
"its a BEAST of a sub and probably the best SQL sub in the classifieds sections right now...plus very rare!"
"DBDon hand made each one of those. Weren't many that were "just alike"....basically, no assembly line of them.
I've had a few different (Inhuman) 15's and both were SUPER nice subs! One (based off me doing a legal 144.5 with a single brahma 15 ported on a jbl 1200.1), I believe had to be in the 146 or so range! Clearly louder and more brutal than my brahma 15 setup"
$540 OBO
Alpine S634
Alpine AI-Net MP3 6 disk changer with 1 cassette included, this changer is in great working condition and the only flaw is a little ding in the metal case on the front of the changer, it is very small but noticible.
$110 OBO
You can contact me via PM or email at phiber-optik@shaw.ca
I am interested in trades and i'm currently looking for a set of 2 12" SQL woofers, IDMAX, FI Q?, XXX or Brahma's etc... and maybe an Alpine in dash media unit, or a higher end Headunit...
Anyways shoot the offers out there!
Picture of the Alpine S634, it has some scratches on the chassis also, far from mint condition, but works perfect, have box and manual also.
I almost forgot I also have a pair of 10" Pioneer Slim subs TS-SW1041D 250 Watts Nominal Power, just 3" Mounting Depth Small Enclosure Use (0.35 ~ 0.7 Cubic Feet)!
I recently bought these for my regular cab ranger and made a nice custom carpeted box to fit behind the seats and still retain the rear speakers, I sold the Ranger without the system and now I don't need these
$350 including the free 3/4" carpeted box with 2 $35 bassworx 12" grills
I also have an Alpine headunit from awhile back, I got it with my new truck but removed it right away, it's in great shape and says on the face it has a "Regulated 1bit DAC", the harness is in good shape, pretty basic, doesn't play mp3's but does do burnt cdr's, and it also comes with a 6 disk non mp3 changer with 1 cassette and the long non-AInet cable for the changer
$150 OBO
2500 RMS !?Try 1200.
$540 !?
Try $350.
I wish I could just put some Beyond Audio dustcaps on my HCs and sell em for $550 each...
If you think they are the same as HC's you are wrong...
This sub was hand built with parts made to order, not many alike, not production line china buildhouse shit, they may share the basic motor structure but that is where the similarities end.
If you're not interested in buying then please don't litter my thread with your opinions.
what's the mounting depth on the XXX's??? And these are just the mid's no co-ax or separates or anything like that.. If i remeber correctly, and may very well not be, but they only had mids when first came out right?
Pls & Thx
The FACT is, no parts on this sub (softparts, coils, supplies ect.) whether they're hand built to order or not, make it 2400 rms (including the soft spiders). BA labeled it conservatively at 1200 rms for a reason. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Pardon my opinion on your pricing. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Pls & Thx
correct just mids, I believe the mounting depth is 3 5/8" but i can double check tomorrow
Phiber Optik
Phiber Optik
BC Canada
Phiber Optik
