Sold FS: Rainbow Cal 25 fabric dome tweeters
FoxPro5
Causal wanderer
Here they are. Get them while you can. This pair is from the X Line comp set: http://car.rainbow-audio.de/products/details.php?lan=2&pro=1&lin=11&art=231439
They are NOT the same as the silk VOF tweets use in the Power Line. As far as I can tell they are the same as the Cal 25 used in the older Professional line as well as the Arc Audio ACS set.
Great overall tweeter. Smooth sound with nice detail. They haven't really even had enough play time on them to be broken in yet....
Specs...
CAL 25 Fabric
0.98 inch
Part number: 231439
Peak power handling: 150 Watt
Nominal power handling: 100 Watt
Minimum amplifier power: 75 Watt -
Input sensitivity: 90 dB 1W/1m
Frequency response: 1.800 - 23.000 Hz
Impedance: 4 Ohm
Crossover slope: 12 dB/Oct.
Crossover frequency: 3.400 Hz
Thermal protection: PTC
$125 shipped in the US //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
Nice, I wish I could use them but they will not work for me..
Free Bump!
Thanks.
But I think you can use them....Cal25's are magic //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The factory xover point on the passive is around 3khz IIRC. I'd say no lower than 2k with a steep slope IME. Don't have the Fs on them for you sorry. I had them at 3.15hz at 12db/oct, A pillar, about 45* off axis with 85w rms.
FoxPro5
Causal wanderer
FoxPro5
3 octaves higher
Ryan from Ohio
