Sold FS:PPI Flat Piston Pro12 old school rare
j0ne
la
First off...How do i post the pics? Noob I know!
Hello.
After some consideration I have decided to try and sell these awesome subs. It was a tough choice, but I could use the $$.
I am looking for $250 plus actual shipping each.
These are old school USA crafted (circa '98 see pictures). These have been stored for 9 years. Was originally going to be used in an SPL set up. The trim around the mounting ring has been chromed for looks on both. This is an awesome SQ woofer that does not slack at loud volumes. I have original boxes, manuals, mounting hardware, mounting stencil, ppi-ware order form...Everything is here! Both woofers work perfectly, have both been mounted and tested for under 3 hours. Some SLIGHT wear from being mounted. Being very anal, I rate these 9/10 cosmetically, and 10/10 functionally.
Specs
Normal Power Handling 300W rms
Voice Coil Diameter 3”
Voice Coil Type / Former edge wound/Kapton
Resonant Frequency 43Hz
Qts-Total Damping 0.52
Qms- Mechanical Damping 2.51
Qes- Electromagnetic Damping 0.66
Vas- Equivalent Compliance Volume 43.97 Liter
DC Resistance of V.C. 4W / 8W
Sensitivity(SPL at 1W) 89.31 dB
Linear Excursion ±5.5mm
Peak to Peak Excursion ±13mm
Mms- Total Mass 114.7 grams
Sd- Piston Area 0.0512 sqM
Bl- Magnet Product 13.74 TM
Diaphragm Material carbon fiber/Nomex honeycomb
Basket Material cast aluminum
Net Weight 24.18lb
Dimensions 12.27” dia. X 4.75” H
Mounting Diameter 11.125” dia.
Check this thread for some comments from another forum regarding the Pro12's:
CLICK HERE
Now for Pictures...
1st Sub
In the Box, Manuals, Paper work...
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12021Large.jpg
Its not clearly visible in this pic, but it says Jan. 08 1998, which i will go out on a whim here and say is about when the woofer was constructed.
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12020Large.jpg
8 ohm
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12015Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12014Large.jpg
This woofer stands at 4.5" tall.
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12012Large.jpg
Flat
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12011Large.jpg
Heavy: 24 Lbs
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12010Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12005Large.jpg
2nd Sub:
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12004Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12003Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12002Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12001Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12009Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12008Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12007Large.jpg
http://img.photobucket.com/albums/v316/juancarlosedwardo/PPI%20Pro12/Pro12006Large.jpg
Send me an e-mail Quality12Volt@Gmail.com
Located in Southern California 93551, Local pick up is welcome!
Thanks for looking!
Jon
j0ne
j0ne
la
j0ne
BP1Fanatic
BP1Fanatic
