Sold FS: Phoenix Gold Xenon 200.2
chaunb3400
I ship faster than you!
I have for sale my PG Xenon 200.2 it has been painted flat black.. Great amp, no matter what the ohm load is it will do the same power 1-4ohms stereo and 2-8ohms mono..It is pretty underrated so expect about 20%-35% more then rated depending on current. Great for a set of comps, or a low powered sub stage. It comes with the original box, i do not have the rubber tabs for it..Asking $165shipped next day air...any questions pm me..Thanx
# RMS Power @ 1,2,4 Ohms: 200W x 2 @ 14.4V
# Bridged RMS Power @ 2,4,6,8 Ohms: 400W x 1 @ 14.4V
# Signal to Noise Ratio: > 100 dB
# Bass Boost: 0 - 18 dB
# XeTUNE- Advanced input and signal processing circuitry
# Top-Mounted Controls
# 24 dB / Octave Crossover
# Twin-T Variable 0 - 18 dB Bass Boost at 45 Hz
# Auxiliary Outputs Route Full Range Signals
# Tri-Linear Capability Allows Simultaneous Stereo and Bridged Operation
# XeFlow- Thermal feedback system with output optimization
# Bottom-Mounted Extruded Aluminum Heatsink
# Expanded Metal Mesh Intake & Exhaust Vents
# Ultra-Quiet Variable Speed Fan
# Temperature Monitoring with Automatic Output Optimization
# Superbrite 5mm LED Power Indicator
# XeLOAD- Full power with automatic load sensing
# Load Sensing Optimizes Power Supply and Output Stage
# Maximum Power Output From 1 - 4 Ohms Stereo or 2 - 4 Ohms Bridged
# High-Current Triple Darlington Output Stage
# 150-Volt, 15-Amp, 60 Mhz Sanken Output Transistors
# Direct Insert Speaker Terminals Accept Up To 8 Gauge Wire
# 4 Gauge Power Terminals with Removable Rubber Grommets
chaunb3400
chaunb3400
Hussleville, AL
chaunb3400
