FS*****Phoenix Gold RSD 250.2 ( 2 Channel )
350zspl
Owners Manual Link http://download.phoenixphorum.com/Manuals/Amplifiers/RSD/RSd%20250.2%20amp%20manual.pdf
250 watts, RSd 2-Channel Amplifier
Power Output:
4 Ohms: 76 watts x 2 chan.
2 Ohms: 113 watts x 2 chan.
High Speed, High Current MOSFET Switching Power Supply
On Board Protection Circuitry
Multi-Function Protection Indicator
Built-In High/Low Pass Crossover, 40 Hz - 400 Hz @ 18 dB/oct.
Variable Bass Boost(0 - 18 dB)
Wide Range Input Sensitivity Adjustment
Line Level Inputs
S/N Ratio: 85 dB
Dimensions: 12.9"L x 11.2"W x 2.4"H
$70 Including Pay Pal Fees
Free Shipping USPS Lower 48
you are having about as good of luck as I am selling mine!
i see that
Mine may be that its power rating
eventually it will go , at $50 all in , about as low as I am willing to go
I for sure what to get with you 3rd week in July when I will have the funds , to schedule the installation for the central AC work we spoke of. 100% certain on that .
Thanks Bro
Can you bridge it? 300 watts x 1 would be more appealing in your description 2ohm or 1 ohm stable? imo glws
I appreciate the post , the initial post will not let me edit it . So I am not able to add any information. However the 1st part of my 1st post has the link to the owner's manual and that would clear up any questions related to power output.
What you will find in the instruction manual is:
AND
It IS able to be bridged in a mono configuration with 4 ohms being the lowest load, however it does not state the power output bridged at 4 ohms.
Lastly , the amp can be used as High Pass, Low Pass, AND Full Range
$45 including USPS standard shipping to the lower 48 , and including Pay Pal fees
350zspl
350zspl
WPB Florida
350zspl
