Sold FS: PG TEQ4 Phoenix Gold 4 Band Parametric EQ
Scott@GZUSA
Pro Seller
Supporting Vendor
I have a new PG teq4 4 band parametric eq with variable center and Q. It wont fit my dash right so I am going with a Eclipse deck.
Looking for $75 shipped
Will get pics up later
Number of Filters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4
Center Frequency Ranges (Hz) . . .20-120, 50-500, 200-5k, 5k-20k
Variable Filter Q . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 to 4
Dimensions, Chassis (inches) . . . . . . . . . .7.25 L x 4.82 W x 1.0 H
Frequency Response . . . . . . . . . . . . . . . . .+/-1dB, 20Hz to 20kHz
S/N Ratio (A-weighted) . . . . . . . . . . . . . . . . . . . . . . . . . . .>110dB
Total Harmonic Distortion . . . . . . . . . . . . . . . . . . . . . . . . . . .0.02%
Input Signal Level . . . . . . . . . . . . . . . . . . . . . . .0.1 to 8 Volts RMS
Output Signal Level . . . . . . . . . . . . . . . . . . . . .0.1 to 8 Volts RMS
Input Impedance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10k ohms
Output Impedance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .30 ohms
Filter Boost/Cut Range . . . . . . . . . . . . . . . . . . . . .-15dB to +15dB
Power Supply Operating Range . . . . . . . . . .10.5 Vdc to 15.5 Vdc
Typical DC Current Draw . . . . . . . . . . . . . . . . . . . . . . . . . . .1 amp
Scott@GZUSA
Pro Seller
Supporting Vendor
Scott@GZUSA
St. Louis
Scott@GZUSA
