Sold FS: Performance Teknique Amp (maybe blown)
dafobbishon3
i have a performance Teknique ICBM-772.
i don't know if it's blown but all i know is that one of the channels don't work.. so i had to go buy a new amp so i'm selling this amp with one non workin channel. i pulled up a DMM and there were no volts pulling out. of one of those channels so i would assume it's a blown channel.
http://www.millionbuy.com/pericbm772.html
i'll ask for 65$ shipped OBO
Product Features:
* Maximum Output Power @ 2 Ohms: 400W x 2CH
* Power Output @ 2 Ohms: 175W x 2CH
* Power Output @ 4 Ohms: 125W x 2CH
* Power Output Bridged: 350W x 1CH
* THD: 0.05%
* Signal to Noise Ratio: >95dB
* Frequency Response: 15Hz to 40kHz
* Crossover: Separates
o High-pass: 50Hz to 1kHz Variable
o Low-pass: 30Hz to 500Hz Variable
o Slope: 24dB Octave
o Subsonic Filter: 10Hz to 100Hz Variable
o Bass Boost: 0 dB to 18dB Variable
* Input Sensitivity: 200mV to 6V Variable
* Low level Input Impedance: 47K Ohm
* Damping Factor: 180 into 4 Ohm
* Channel Separation: >80dB
* High & Low Level Input through RCA
* Double Sided PCS
* Dual Protection (Thermal & Short Circuit)
* RCA Line Out
* Power & Diagnostic LED Indicator
* 2 Ohm Stable
* Soft Delayed Power On
* Tri-Mode Capability
* Power Supply Consumption (Bridged RMS): 36A
* Fuse Rating: 20Ax2
* Dimension (WxHxL): 9.96" x 2.12" x 15.90"
i'll post up pics when i get home in about 20 minutes.
PICS
well i was lookin at the amp. and one of the channels, instead of a clear cover like shown in the picture, as you can see at the third picture from the top, the very first speaker input channel with a blue wire coming out of it, it's really white and cloudy, what couldve caused that?
dafobbishon3
dafobbishon3
Texas
dafobbishon3
