Ok, so I had to call in sick for the week because I caught strep throat and I want to play in a paintball tournament this coming weekend. So I need to free up some money. Here are the things I have gathered for my Honda Fit build, its going to be put on hold for a couple of weeks. All items are my personal items I purchased for my own vehicle.
I have a pair of SSA Icon D1's that are literally BNIB, one i opened to check the top of it, the other is still sealed
Normal Price on these is $239.00 Each, I'm willing to let mine go for 425 shipped on the pair or 225 shipped each. They will be shipped and insured to there full value. These subs carry full warranty.
# 3” wide, 4 layer, copper voice coil
# Push terminals
# Pulp Fiber Cone
# Dual stiff progressive spiders
# FEA optimized motor structure
# 3" Anodized aluminum former
# Heavy Duty Lead wires
# Design and hand crafted in USA
# Fs 30.7
# Qms 5.60
# Qes .41
# Qts .38
# Mms 190 g
# Sd 310 cm^2
# Vas 19.1 l
# Bl 16.4
# Spl 83.1 1W/1m
# Xmax 20.5mm
# Wattage: 1000RMS
# Displacement: 0.12cuft
Next I have the amps I was going to power these bad boys with, a pair of SAX 100.2s. One is BNIB and I would like $180 shipped for it. The other is slightly used but still looks BNIB, I would liek $175 shipped for it.
These amps are really clean amps and have magnificant power output even as a sub amp. I have one in my g/fs car on a RD Alpha 12 and it sounds AWESOME.
SPECIFICATIONS:
* 100 x 2 watts @ 4 ohms
* 200 x 2 watts @ 2 ohms
* 400 x 1 watts @ 4 ohms
* Damping Factor > 350 @ 4 Ohms
* 0.2v - 6v adjustable input sensitivity
* 10 Hz - 40,000 Hz Frequency Response
* Channel Separations: 75 dB
* > 90 dB S/N Ratio
* 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
* Selectable HP / LP / FULL crossover
* 35 Hz - 300 Hz adjustable 18dB Low-Pass Crossover
* 75 Hz - 2,000 Hz adjustable 18dB High-Pass Crossover
* 0 - 18 dB adjustable bass boost with 45 Hz center frequency
* Wired Remote Control unit included
* 3x 20 Amp Internal Fuses
* 13 3/8" L x 9" W x 2" H
I can get real pics of these things if you want, but I think my reputation speaks for itself on this site. Thanks for looking and buy this stuff so I can afford the next tourny.
# Push terminals
# Pulp Fiber Cone
# Fs 30.7
# Qms 5.60
# Qes .41
# Qts .38
# Mms 190 g
# Sd 310 cm^2
# Vas 19.1 l
# Bl 16.4
# Spl 83.1 1W/1m
# Xmax 20.5mm
# Wattage: 1000RMS
SPECIFICATIONS:
* > 90 dB S/N Ratio
