Fs os kicker zr240
  • 2
EXTREMECHEVYMAN
KICKER ZR240
performance 10/10 looks 7/10 only because 2 mounting feet are broke. missing end caps an badge
75.00 shipped in conus
stereo, bridged mono, or Tri-Way output
frequency response 10-28,000 Hz
60 watts x 2 at 4 ohms
240 watts x 1 in bridged mode
120 watts x 2 at 2 ohms
MOSFET power supply
module docking port with 2-way active crossover (80 Hz low-pass, 100 Hz high-pass, 12 dB/octave)
discrete output transistors
silent turn-on/off circuitry
15-5/8"W x 2-13/16"H x 10-1/16"D
SOLD TO quaddropper, atxbasshead, chuck5766, MrFixIt, Austin175, mwerling1212, Boomsday, maverickdog8, ed70805, SPLII, extreme, soundaround, all_rice, ampjunkielikeme, DonH, Wheres The Butta, lantzdarla, Tcartney, Slam, cuseikan, sleepingciv, rachidfunaki, RidnClean
TRADED WITH 00ram360, chuck5766, SacTownBully84, blfuller123, RobTabor
BOUGHT FROM slim2fattycake, imasonic
730
EXTREMECHEVYMAN
EXTREMECHEVYMAN
Washburn, Tennessee, United States
EXTREMECHEVYMAN
    May 24, 2024
    May 23, 2024
