SOLD to Ryan, Belunt
http://render2.snapfish.com/render2/is=Yup6aQQ%7C%3Dup6%3DzqH%3AxxqUD7qRUrKxzX7BHpUUKxgXPPa%3F87KR6xqpxQQQaxaoQxJnJxv8uOc5xQQQoePlGnoaQnqpfVtB%3F*KUp7BHSHqqy7XH6gXPPa%7CRup6lQQ%7C/of=50,590,442
Cut and paste above link to see a picture
Selling my Orion 8004 4 channel amp
RMS is 4x100
Comes with end caps, and manual
Has built in crossovers and other features
On the very top of the heatsink on one of fins there is a scrape. It blends in and is not very noticable due to its location.
$200 plus shipping of 25 pounds from 92131
bzulka2@yahoo.com
Thanks, Bryan
Amplifier Type: Multi-Channel
RMS Power @ 4 Ohms: 100W x 4
THD at 4-Ohm RMS Power:
Bridged RMS Power @ 4 Ohms: 400W x 2
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0-16 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 85 dB
Fuse Rating: 100 amps
Polished gunmetal heatsink with etched Orion logo
Mil-Spec double-sided circuit boards
Massive power supply
Complementary bipolar output stage transistors
Variable 20-3,000 Hz high-pass and low-pass crossovers
Variable 0-16 dB INTELLi Bass equalization
Proprietary Copy/Master feature for multi-amp systems
Selectable preamp outputs
Copy/Master switch for gain and crossover matching
Separate variable crossover for preamp outputs
Combine crossovers for band-pass operation
Selectable 2/4-channel input
Satin finish direct-wire power and ground connections
Removable end caps
Optional RGC-1 remote gain control
RMS is 4x100
bzulka2@yahoo.com
Thanks, Bryan
Preamp Outputs: yes
Bass Boost: 0-16 dB
Removable end caps
