I'm selling a orion 225g4.It has scratches and marks on it and i need $120 shipped.
SPECS:
25 w rms x 2 ch @ 4 ohms
50 w rms x 2 ch @ 2 ohms
100 w rms x 2 ch @ 1 ohm
200 w rms x 2 ch @ .5 ohm
100 w rms x 1 ch @ 4 ohms
200 w rms x 1 ch @ 2 ohms
400 w rms x 1 ch @ 1 ohm
All power ratings are at 12v expect more in real world 13.5-15.0 v
Tri mode cap[able
freq resp 20 Hz-20kHz
s/n ratio > 100 dB at rated power
Dampening factor > 400
Rca input voltage 200mV- 5V with gain adjustability( up to 9 Vrms at minimum gain setting
Low pass cont variable 40Hz- 5kHz
Highpass cont variable 10Hz- 1 kHz or 100Hz- 10kHz
Intelli Q boost range 0dB- +10dB
Phase adjustment for each channel
Independent gains for each channel
Aux out Rca's
SPECS:
Tri mode cap[able
Aux out Rca's
