Sold FS: 2 RF T3002's
ruger
CEA 2006 Ratings :
Variable 40-4,000 Hz Low-Pass or High-Pass Crossover / 12 dB / Octave Butterworth Crossover Alignment Variable 35 – 70 Hz Bass EQ / Variable 0 – 18 dB Para-Punch Boost / Removable Connections Shroud 4 Gauge Power and Ground Connections / Built-In ATC Fusing / Preamp Outputs 1 Ohm Stereo / 2 Ohms Mono Stable / Wired Remote Para-Punch Bass Control
*****-ana design simplifies the input circuit path for optimal performance
MEHSA (Maximum Efficiency HeatSink Application) yields up to 5 times better heat transfer from the Mosfet devices to the heatsink Keeps the amp cool for increased efficiency and reduced distortion integrated PCB plenum, Custom designed TO-247 output Mosfets for thermal stability / Military Specification (Mil Spec) Glass Epoxy circuit boards.
Birthsheets:
http://forum.realmofexcursion.com/showpost.php?p=45007&postcount=3
refs on CA and ROE:
B,HCCAfan,B,TypeRBass,B,GalacticMonkey,
B,Mattz-us3-ike557,B,ROE,B,Angrytrucker78,
B,Stratusrt01,S,momentarylapse7,S,MTXThunder9500,
S,Audiobahnaholic,T,CoreyAnderson.
bought these new in jan 06, used them for 6 mos. Very nice amps.
ran one on a set of rf power 5 1/4 comp. and the other on my 2 subs @ 4ohms stereo.
both are painted by me, not a very good job but they are bulletproof amps functionally.
7/10 cosmetic 10/10 func. looking for 165 shipped ea.
Thanks
new price $150 shipped each.
rated:
50wx2 @ 4ohms
tested 14.4v:
around 200wx2 @ 4ohms
great for a set of components
Stable
will trade 1 for a 50ft roll of 1/0 kicker hyperflex wire.
Thanks
from the birthsheet link in the first post
at 14.4v around:
Components: Stereo
200w x2 @ 4ohms
300w x2 @ 2ohms
350w x2 @ 1ohm
or
Sub/s: Mono
400w x1 @ 4ohms
600w x1 @ 2ohms
ruger
ruger
USA
ruger
