Guys - I have a bad *** sub that I need to let go here. These are difficult to find these days as ED has replaced them with their newer line. This was ED's top of the line sub back in the day.
I had planned to run this wired at 1 ohm but I don't have the charging system for it....I got the dimms pretty bad. This sub is loud and can really thump especially if you feed it the power it wants.
I rate it 9/10 for functionality and 6.5/10 for cosmetic condition. There is a small hole in the surround that has been repaired with silicone sealant. The performance is not affected by it and it does great through full excursion.
It is one heavy mofo weighing in at 31 lbs.
Here are the specs I was able to dig up on it:
T / S Parameters
Qts : 0.49
Qes : 0.57
Qms : 3.56
Vas : 54.88 L
Sd : 0.0312 m^2
XMag : 20.3 mm
XSus : 21.1 mm
XMax : 20.3 mm
MMd : 165.38 g
Re : 2.39 ohm
Fs : 28.63 Hz
Bl : 11.36
Physical Loudspeaker Data
Model : e10A.22
Mounting Depth : 6.1" (154 mm)
Mounting Diameter : 9" ( 228 mm)
Overall Loudspeaker Diameter : 10.5" (266 mm)
Extraneous Information
Coil Type - Alumn. Former Type - Alumn.
Coil Size - 3"
Spider design - Progressive
Number of spiders - One
Spider size - 8.0"
Motor Width - 7.125"
Motor Slugs - Dual 1"
Driver Min Power (Wrms*) Rec Power (Wrms*) Max Power (Wrms*)
10A.22 100 800 1400
Min Power - This is the least amount of power we recommend running into said driver to extract
kind of potential out of it.
Rec Power - This is the recommended power we recommend in order to extract everything the driver is capable of doing in a extremely small box.
Max Power - This is the maximum amount of power we safely condone putting into your speaker in a correctly done stereo set up.
(Wrms*) - Watts rms
Pictures:
Asking $195 shipped in the US via FedEx Ground w/ tracking.
Let me know if you have any questions. Feedback in sig. Thanks for looking //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
T / S Parameters
Qts : 0.49
Qes : 0.57
Qms : 3.56
Vas : 54.88 L
Sd : 0.0312 m^2
XMag : 20.3 mm
XSus : 21.1 mm
XMax : 20.3 mm
MMd : 165.38 g
Re : 2.39 ohm
Fs : 28.63 Hz
Bl : 11.36
Model : e10A.22
Coil Size - 3"
Spider size - 8.0"
10A.22 100 800 1400
(Wrms*) - Watts rms
Pictures:
