fs or trade eclipse avn 6600
matrxx dude
TEAM DB UNIT
as stated,900 cash money or maybe some trades plus money,let me know.thnks john.
The Eclipse AVN6600 DVD player fits in your vehicle's double-sized, 4" tall dash opening, offers a wide variety of entertainment for the whole car, and provides accurate GPS navigation throughout the U.S. The 6.5" video screen displays your movies in vivid detail when you're parked, and acts as the touch-panel command center for the entire system when you hit the road.
Ready to navigate?
Just pop in the included map DVD-ROM, which contains the detailed street maps of the U.S. As you drive, you'll get both visual guidance and voice prompts that announce upcoming turns. Use the intuitive menus to enter a street address or intersection, or select from the 6 million points of interest, including restaurants, hotels, and gas stations. You can also customize your route preferences so you take only the kinds of roads you like to drive.
Read More
City View mode makes navigating even easier by providing 3-D renderings of buildings in select major metropolitan areas. You can use specific buildings as landmarks, so you know you're still on course.
Two DVD slots
You won't have to sacrifice entertainment, thanks to the AVN6600's two DVD slots. The first slot houses your map DVD-ROM, while the second lets you play a DVD or CD. As the system tells you where to go, you can listen to your favorite music on standard CDs or custom MP3/WMA mixes you've burned on CD.
Add a rear video screen and wireless headphones to entertain the kids in back while you drive. Dual-zone mode lets you send DVD picture and sound to the back seat, while you enjoy another source, like the radio, up front.
Big-time sound
Don't have a surround-sound speaker setup in your vehicle? Circle Surround II can simulate surround effects with just four car speakers — it's perfect not only for your DVDs, but for applying surround effects to stereo recordings, too. You can fill out your music's bass effects, and also compensate for low-mounted door speakers by bringing the sound up to ear level.
You also get a seven-band equalizer that's easy to adjust. You can simply trace your desired EQ curve with your finger on the touchscreen, instead of having to adjust each of the seven frequency points individually.
System expansion
System expansion is on the menu, too. With Eclipse's optional control interface, you can connect and control your iPod®. Integrate an Eclipse SIRIUS satellite radio or HD Radio tuner for the best radio entertainment around. Add an Eclipse rear-view camera to get a clear view when you back up. And three sets of 5-volt preamp outputs send a clean signal to the external amplifiers you use to drive your speakers and subs.
Details:
DVD/CD player with navigation and built-in amplifier (15 watts RMS/50 peak x 4 channels, CEA-2006 compliant)
fits double-sized (4" tall) dash openings
motorized 6.5" LCD video screen with adjustable display angle and touchscreen controls
plays CDs, CD-Rs/RWs, DVDs, DVD-Rs/RWs, DVD+Rs/RWs and MP3/WMA discs
GPS navigation (includes GPS antenna and map DVD-ROM) featuring map and voice turn-by-turn guidance
City View mode — 3-D maps that render accurate representations of specific buildings in many cities
6 million points of interest (hotels, restaurants, gas stations, etc.)
customizable route preferences
two DVD slots
Circle Surround II — simulates surround effects with four car speakers
five soundfields: cathedral, club, concert, live, theater
7-band parametric EQ
24-bit digital-to-analog converter for full, detailed sound
SIRIUS Satellite Radio-ready (you can add SIRIUS for under $100, plus subscription)
compatible with Eclipse iPod control interface, HD Radio™ tuner, TV tuner, and CD changer
audio/video input
rear-view camera input
audio/video output
dual-zone capable
5-volt front, rear, and subwoofer preamp outputs
AM/FM tuner
18 FM/6 AM presets
FM sensitivity: 13 dBf
warranty: 1 year
Specifications:
Hard-drive based A/V navigation system
Motorized slide-out faceplate
Plays: CDs, DVDs, CDs and DVDs with JPEG images, MPEG 1/2 video files, and DivX movies (DivX Ultra certified)
iPod ready (requires KS-PD100 adapter)
Bluetooth ready (requires KS-BTA200 adapter)
Satellite radio ready
40GB HDD
3.5" LCD screen
Rear-view camera ready
J-BUS terminal
CD changer compatible
Steering wheel remote control ready (requires PESWIAKJ adapter)
Navigation Features
16GB Internal map database
No disc change necessary
Will operate alongside A/V entertainment
13 Million POI (Points Of Interest)
Extensive map coverage of US, Canada and US Virgin Islands
Multiple route calculation options
2D or 3D map viewing angles
WAAS capable GPS
Built-in RDS-TMC traffic tuner helps avoid traffic jams
Audio/Video Features
24GB hard drive holds up to 460 CD albums
ID3 tag information displayed on-screen (album, artist, title)
GIGA MP3 MULTI (allows playback of MP3/WMA/WAV from DVD)
High-speed copying of MP3/WMA/WAV files
JVC original lossless recording
DVD audio compatible
DivX compatible
12-bit/108 MHz Video D/A converter
Optical digital output
Gold-plated A/V output terminals (front/rear/subwoofer/video)
Telephone muting
Hand-held remote included
Specifications
Preamp Outputs: 3 + video
Preamp Voltage: 5 volts
RMS Power: 20W x 4
Peak Power: 50W x 4
DVD Frequency Response: 16-22,000Hz
FM Mono Sensitivity: 11.3dBf
Signal-To-Noise (S/N) Ratio: 95dB
Total Harmonic Distortion (THD): 0.01%
Features:
Theres nothing like having a navigation system in your car, for making your driving easier.
A clean moving-map display is the way to go, and now with JVCs KD-NX5000 you dont have to compromise on any other features either.
The KD_NX5000 is not only a navigation unit; it is also a full-featured audio and video playback system.
Since it is based on a hefty 40GB hard drive it has the ability to run the navigation system while the CD or DVD system is operating, (youll need an external monitor for the video to operate simultaneously).
An internal hard drive also means that you won’t have to load navigation discs – its all built-in.
The hard drive contains detailed maps for the US, Canada, and the US Virgin Islands, and has a database of over 13 million Points-Of-Interest.
Not only will it display your route on-screen, but since the WAAS capable internal GPS gives you accuracy of better than 3 meters.
The unit features a built in RDS-TMC tuner so you can get real-time traffic information to keep your travel time to a minimum.
There is no danger of skimping on other features since JVC has based the KD-NX5000s stereo on its other high-end head units, plus they've added a DVD player with DivX compatibility.
The internal hard drive adds even more functionality since you can actually record music to it.
The KD-NX5000 can accept an iPod with the KS-PD100 adapter, but you can also just record directly from CD to the internal drive.
The drive will hold up to 460 CDs worth of MP3s so you can have instant access to even the largest music collection.
A set of three audio outputs and a set of optical digital video outputs also make expanding your system a breeze.
JVC also realizes where technology is heading so they've added Bluetooth capability as well.
With the optional KS-BTA200 you can experience hands-free calls, streaming audio and phone book control and transfer.
With voice-recognition mobile phones you can even dial just by saying the name in your phone book.
The KS-BTA200 also has a pass-through so you can daisy-chain an iPod adapter, a satellite radio receiver or a CD changer
matrxx dude
TEAM DB UNIT
matrxx dude
tifton ga
bumpin buick
