Sold FS or FT: Tru, CDTaudio, Alpine, Amp, Speakers, Sub, HU
Thewavecaraudio
I have a barely used Tru Tech S44 dual mono amp.
4 STEREO RMS
65W x 4
2 STEREO RMS
100W x 4
4 STEREO + MONO RMS (3CH)
65W x 2 + 200W x 1
4 MONO RMS (DUAL-MONO)
200W x 2
for more specs :
http://www.trutechnology.com/products/steel/s44_08.html
Price asked is 475 usd OBO
CDT audio es-200us 2way + upstage crossover
used for around 1 year
one has a small blemished on the grill on it but you have too look closely to find it..
ES-200US
(2-way with UpStage Built-In Design)
This compact “silver bullet” module implements the image enhancing upstage system while holding complexity to an absolute minimum. This versatile crossover module implements a two-way crossover with large high quality parts or alternately may be programmed to drive an upstage high-mounted second Tweeter. This dual functionality is jumper selectable. In simple two-way mode the tapped inductor design in the Satnet 560 is used. Dual jumpers moved together change the crossover to upstage mode. In the upstage mode the drive to the mid-woofer and Tweeter are tapered off to interface with the upstage Tweeter. This tapering is adjustable with three “L” settings and two “C” settings. This alters the crossover frequency and response shape (damping). The image Tweeter furthermore has seven selectable levels available. Upstage crossover is typically at 8kHz. Main Tweeter crossover is transient optimized at 3.7kHz. No protectors are used.
I' selling because i'm going active
Asking 180$us obo
I have this nice comp set, it is BNIB
I would let go for 400$ + shipping
I can throw in DRT-26 silk, or aluminum ou titanium it as you want...
I also have a pair of ES-06 so could switch the es-6 for the es-06 for an extra $$
Selling as a package
Alpine CDA-7949, used, in great shape, faceplate is in good shape, only thing is the button for eject is missing, need to use a needle or small screwdriver to push the mecanism but still easy to open
Specs & Features :
Copper chassis
Competition Grade 4V pre-outs
Dual Regulated 1 bit DAC
3 Gold Plated Pre-outs
BBE DSP
8 times over sampling
Disc Memory
Blackout Function
Independent Sub Woofer Control
AI-NET
352.8kHz Sampling Rate
5Hz - 20Khz Frequency Response
THD at 0.008%
Signal to Noise Ratio 95dBA
Alpine CHA-S604 CD changer
6 disc changer
Perfect fit if you want to play CD-R easily with the 7949
comes with ai-net cable
I want 220$ Cnd$ so take advantage of the strength of your US$
use this site for conversion xe.com and add 2.5%
for now should be around 190$ us for a nice SQ unit and the changer
I also have 2 CDTaudio HD SQ-10 sub they are BNIB (sealed box)
500-600wrms svc 4 ohm 10'' sub
tech specs:
http://www.cdtaudio.com/pdf/HD-10SQ%20%2010_.pdf
Price asked is 360$ for both or 200$ each
For last I have one pair of CDtaudio CL-60CV also BNIB
I would let them go for 110$
The CL-60 speakers are designed and built for the unique demands of the car audio environment. They are built to deliver the truest, in-car sound possible, the most accurate and natural performance ever-the type of performance that has earned our design team countless awards and unanimous praise from around the world. Smooth and accurate highs. Our patented swivel tweeter technology and our exclusive use of soft dome tweeters combine to deliver superb detail and incredible clarity.
6.5" 2-way convertible system
Mid woofer: stamped 6.5"
Xover: Satnet 400
tweeter: 3/4" silk dome tweeter
Power handling: 130Watt RMS @ 100Hz High-Pass
Frequency response: 60-20kHz
Sensitivity: 91.3 dB
Impedance 4 Ohm
Surface & flush mounts Including post for coaxial mounted tweeter.
CDT Audio CL60 CDT Audio CL 60 Classic Series 6.5" 2 Way CONVERTIBLE Speaker System
Replied on the post, by pm or at thewavecaraudio@hotmail.com
Could accept trade, i'm looking for Alpine IVA-W200, sinfoni 150.2x , 1/0awg flex power cable, could always ask if you have something else
Thanks for looking
Alex
Thewavecaraudio
Thewavecaraudio
Trois-Rivières
Thewavecaraudio
