Sold FS: New Orion 600D
backtofront001
I got the Orion on friday the 18th of August. Ordered from ikesound and with shipping it came out to $160. It is a nice looking amp, however it did not work out for me because my RL-P wants more power. I have the box it came in and everything. Max playing time on the amp is probably 2 hours and not more. Like I said I just got it. No scratches no nothing. This amp is new...it did not satisfy my power needs so i am going to replace it with a Hifonics BXi 1206D. I will sell this for $145 shipped
can you do me a favor and put the spces up for it all the ones i find contradict eachother
Product Description:
Class-D Monoblock Amplifier
RMS Power Output:
250 watts x 1 chan. @ 4 Ohms
400 watts x 1 chan. @ 2 Ohms
600 watts x 1 chan. @ 1 Ohm
Intelli Q bass optimization circuit and remote gain option
Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs
Selectable 12/24 dB/octave variable low-pass filter
Copy/Master feature supports gain and crossover adjustment matching in multiple amp
Allows external bridging of two matched gain amplifiers
Switchable phase invert function
Heavy gauge direct-wire high current satin finish power and speaker terminals
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 250 watts x 1 chan.
RMS Power (2 ohms) 400 watts x 1 chan.
RMS Power (1 ohm) 600 watts x 1 chan.
Bridged RMS Power Not Bridgeable
Peak Power Output 1200 watts approx.
Min. Impedance Unbridged 1 ohm
Min. Impedance Bridged Not Bridgeable
THD @ Rated RMS Power 0.9%
Speaker Level Inputs No
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover HP (20 - 150 Hz), LP (30 - 250 Hz)
High-Pass Crossover N/A
Low-Pass Crossover N/A
Subsonic Filter N/A
Signal-to-Noise Ratio 80 dB
Channel Separation N/A
Bass Boost 0 - 10 dB
Bass/Gain Remote N/A
Fan Cooled N/A
Fuse Rating 50A x 1
hifonics amp's bench at 91% of rated power @ 14.4v no less.. under 14.4v it drops even worse.. 91% at rated power @ 14.4v is 1092 MAX could even be less... i'd stick with the orion which is probably pushing 700wrms maybe more and save some money.
think about a different box before a new amp
backtofront001
backtofront001
San Francisco
backtofront001
