Sold FS: NEW Alpine IVA-W200 headunit mp3/cd/dvd 6.5" screen
intence
Means of Contact: alandang@cox.net or PM me here
Description: see below
Price: from now (6/18) until wednesday (6/21) ill let this go for $850 SHIPPED!
I bought this brand new for $1050 but I've decided to stick with the stock headunit and use this money elsewhere. This headunit has never been opened. All packaging is still sealed. This retails for $1000 at your local stores but my price is $925 obo. I'm open to offers but low ballers will be ignored. Buyer is responsible for pickup or shipping.
here is some general info:
SOURCE: http://www.alpine-usa.com/en/products/product.php?model=IVA-W200&lang=en&tab=F
FEATURES
Tuner
· • HD Radio Ready
· • Preset Stations (FM:12/AM:6)
· • Auto Memory
· • Local/DX Selection
· • Preset Address Indicator
· • Up/Down Seek
HD Radio™ Ready
· • HD Radio Status Indicator
· • Automatic Digital/Analog Signal Switching
SAT Radio Ready
· • Sirius and XM Satellite Radio Compatible
· • Preset Memory, 3-Bands (18 Channels)
· • QuickSearch Function
· • Category Search
· • Text Scroll
Full Speed™ Connection for iPod®
· • Dedicated iPod Source Selection
· • Direct search function
· • Repeat One
· • Search Mode Selection (Playlist, Artist, Album, Song Title)
· • Shuffle (Albums, All)
CD Player
· • 24-Bit D/A Converter
· • Zero data Mute (0 Bit Mute)
· • Digital Servo
· • Music Sensor Up/Dn
· • Disc Play/Pause
· • Forward/Backward
· • Music Search Function
· • Dolby Digital/DTS Bit Stream Output
· • CD Text, CD Text Display, CD Text Scroll
· • MP3 Text Information Display (ID3 Tag)
· • MP3/WMA Decoder/Playback
· • M.I.X. One (Folder)/All (Random Play)
· • QuickSearch Function (MP3 Files)
· • CD-R/CD-RW Compatibility
DVD Player
· • DVD-Audio Playback (2 Channel mix-down)
· • DVD-R/DVD-RW/DVD+R/DVD+RW Compatible
· • DVD-Video/DVD-VR Playback
· • DTS CD Playback
· • Dolby Digital Bit Stream (with 2 Channel mix-down)
· • DTS Digital Bit Stream (with 2 Channel mix-down)
CD Changer Control
· • Repeat (One/Disc)
· • Music Sensor Up/Down
· • Disc Play/Pause
· • Elapse Time Display
· • CD Text Display/Scroll
· • Multi-CD Changer Control (with KCA-410C)
· • MP3 Changer Ready (CHA-S634)
· • M.I.X. One/All (Random Play One or All)
Bass Engine® Sound Tuning
· • Subwoofer Level Adjustment
· • Bass Center Frequency Control
· • Bass Width Adjustment
· • Bass Level Adjustment
· • Treble Center Frequency Control
· • Treble Level Adjustment
(MMStation/Head Units) General
· • 1 Aux A/V Input and 1 Aux A/V Output
· • 6.5" Widescreen Motorized Monitor
· • 50W x 4 High Power Amplifier
· • Auto Close/Open Capability
· • Rotary Encoder Volume Control (Pop-up Rotary Knob)
· • Black Face w/Blue illumination Buttons
· • 3 PreOut (2V PreOut)
· • Direct Touch DVD Menu Operation
· • Bluetooth® Ready
· • Data Download
· • Visual EQ
· • i-Personalize
· • Bass Engine
· • Subwoofer Level Control
· • Steering Wheel Remote Ready
· • MM Driver Ready (Hard Disc Drive Ready)
· • TDS Amp and Processor Control Capabilities
· • Optical Output
· • Built-in Dolby Digital /DTS Decoder (2-Channel Mix Down)
· • Separate Bass & Treble Control
· • Fader & Balance Controls
· • Loudness
· • S.T.M. (Source Tone Memory)
· • Clock
· • Dimmer-on Input
· • BlackOut Display
· • Rear Camera Input
· • Dedicated Navigation Input
· • Navigation Audio Mix
· • Power Antenna Lead
· • Remote-on Lead
· • Audio Interrupt In
· • Wireless Remote Control Included
· • Demo Function
· • Audio Mute
· • CD Changer Control Function
SPECIFICATIONS
FM Tuner
· • Tuning Range: 87.7-107.9 MHz
· • Mono Usable Sensitivity: 9.3dBf (0.8 μV/75 ohms)
· • 50dB Quieting Sensitivity: 13.5dBf (1.3 μV/75 ohms)
· • Alternate Channel Selectivity: 80.0 dB
· • Signal-to-Noise (S/N): 80.0 dB
· • Stereo Separation: 35.0 dB
· • Capture Ratio: 2.0 dB
AM Tuner
· • Tuning Range: 530-1, 710kHz
· • Usable Sensitivity (IEC Standard): 22.5/27.0 (μV/dBf)
DVD Player
· • DAC Resolution: 24 Bit (Max)
· • DVD Frequency Response: 5Hz-22kHz (+-1dB)
· • CD Frequency Response: 5Hz-20khz (+-1dB)
· • WOW and Flutter: B.M.L
· • Total Harmonic Distortion (THD): 0.03%
· • Audio Output Level: 800mV (Fixed)
· • Operating Temperature: -10C to + 50C
· • Power Requirement: 11-16 volts DC (Negative ground)
CD Player
· • Sampling Rate: 44.1kHz
· • Signal-to-Noise (S/N): 105 dB
· • Frequency Response: 5-20k ±1 dB
· • Horizontal Resolution: 500 Lines or Greater
· • Channel Separation (1kHz): 85 dB
· • Dynamic Range (1kHz): 95 dB
· • Total Harmonic Distortion (THD): 0.008% (at 1kHz)
· • Number of DACs: 2
· • DAC Type: 24-bit D/A Converter
· • Optical Output: Toslink (Dolby Digital/DTS/LPCM)
· • Oversampling: 8x/352.8kHz
· • Wow & Flutter (%WRMS): B.M.L.
Monitor
· • Screen Size: 6.5inch Widescreen
· • LCD Type: Transparent type TN LCD
· • Operation System: TFT Active Matrix
· • Number of Picture Elements: 280,800 pcs (1,200 x 234)
· • Effective Number of Picture Elements: 99.99% or more
· • Display Wide Type: 3 Modes (Wide,Cinema, Normal)
· • Subwoofer Level Adjustment Range: -15dB to 0dB (1dB steps)
· • Loudness Control at 100Hz (Max): +10dB
· • Bass Center Frequency : 60Hz, 80Hz, 100Hz, 120Hz
· • Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
· • Bass Level Control Range: +20dB to -14dB at 60Hz (2dB Steps)
· • Treble Center Frequency: 7.5kHz, 10.0kHz, 12.5kHz, 15.0kHz
· • Treble Level Control Range: +-14dB at 10.0kHz (2dB Steps)
Remote Control
· • Model Number: RUE-4203
· • Dimensions (W x H x D) in: 2" x 4-11/16" x 33/64 "
· • Dimensions (W x H x D) mm: 51mm x 119mm x 13mm
· • Weight: 50g (1.8oz)
· • Battery: 1 x CR2025
Dimensions
· • Din Size: 2
· • Chassis Size (W x H x D) mm: 178mm x 100mm x 165mm
· • Chassis Size (W x H x D) in: 7" x 3-15/16" x 6-1/2"
General
· • CEA-2006 Power Rating (4Ohm@14.4 V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 18W x 4
· • Max Power Output: 50W x 4
· • Pre Output Voltage (Before Clipping): 2V
· • Power Requirement: 14.4 (11-16) V.DC
· • Operating Temperature ( °C/ °F): +32 °F to +113 °F (0 °C to +45 °C)
· • Maximum Mounting Angle: 30° from Horizontal
· • Weight: 2.9 kg. (6 lbs. 22 oz.)
and pics
weird, i thought the second link would work.
well i bought the iva-w200 for $1050 including tax from best buy hence the price im asking.
sorry, to all but im not looking for any trades. my ipod and tape deck work fine for now.
xtremeaudioconcepts pm'd
intence
intence
fairfax
j3bus2k3
