Sold FS: MTX Thunder 502 2Ch
RekD0514
IA
This amp has been sitting in my room for a long time collecting dust. I would like it gone for $125 + shipping or highest offer. It really hasn't been used much at all (maybe a year) and has been sitting over a year. It is in great condition with a lot of life left in it! Send me an email at rekd0514 at aim dot com. I also have the same name on AIM if you would like to send me an IM. Here are some references and my ebay account is rickytheracer on ebay. Send me an message on ebay if you would like to verify.
References:
DIYMA
dwicker@gmail.com
dawgdan aka Dan - ID12D4 v3
tn_audiophile@yahoo.com
Tn_audiophile aka Jeremy - Arc Audio 5150xxk
ptricks@cablelynx.com
skibum aka Todd - Alpine CDA 9815
Sound Domain
lasley1@hotmail.com
FRITO aka Luke - Wiring
Bring97@gmail.com
REBring97 aka Austin - Diamond Audio D661s
MJWillemsen@aol.com
E36m aka Mark – Diamond Audio D661s – Sold
http://www.mtx.com/caraudio/archive/2004amps/thunder502.cfm
Specifications
RMS Power 12.5 VDC
2 Ohm Load 180 w x 2
4 Ohm Load 90 w x 2
Bridged 4 Ohm Load 360 w
Dynamic Power 14.4 VDC
2 Ohm Load 250 w x 2
4 Ohm Load 125 w x 2
Bridged 4 Ohm Load 500 w
Dimensions (with ISO Feet)
12.6"x 9.75" x 2.1"
32.1cm x 24.8cm x 5.3cm
Input
Low Level Input
Crossover(s)
Hi / low @ 40Hz-200Hz - Variable Defeatable
Compression Circuitry
Thunder EQ
RCA Output
Variable Hi, Low or Full Range
Signal to Noise Ratio: ¡Ý110dB A-Weighted
Damping Factor: >200
Frequency Response: 20Hz-20kHz ¡À 0.25dB
Maximum Input: 8Vrms
Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
Crossover: Variable 40Hz to 200Hz, 12dB/Octave Stereo
High Pass, 24dB/Octave Mono Low Pass, or Full Range
I bought a Thunder564 for comps and 7" woofers. If it isn't enough power I'll bridge it for the comps and buy this for the 7s...just a heads up. Matching amps FTW
Thanks for the help and I am glad you like it. Make sure your friend stops blowing fuses on his amp. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
RekD0514
RekD0514
IA
RekD0514
vegang
vegang
