I got a few amps up for sale...
MTX Thunder 1501D amp -$300 shipped
RMS POWER (12.5 Volts DC):
500 Watts x 1 into a 4 Ohm load with less than 0.5% Thd+N
1000 Watts x 1 into a 2 Ohm load with less than 1% Thd+N
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
850 Watts x 1 into a 4 Ohm load
1500 Watts x 1 into a 2 Ohm load
Signal to Noise Ratio:
100dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-200Hz
Maximum Input:
8Vrms
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
EBC External Bass Control
Crossover:
Variable 40Hz to 200Hz, 24dB/octave low pass
Dimensions:
14" x 9" x 2" (35.6cm x 22.8cm x 5cm)
Rockford Fosgate P6002 amp - $150 OBO (This amp I pulled out of a friends car when he got it from an auction. Everything was hooked up so Im assuming it works. It's just im curious as it doesnt have the top cover?)
150 watts RMS x 2 at 4 ohms
300 watts RMS x 2 at 2 ohms
600 watts RMS x 1 at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
CEA compliant
Tri-way capable
requires an 8-gauge wiring kit and an 80-amp fuse ? wiring and hardware not included with amplifier
MOSFET power supplies and output stages
MEHSA transfers heat efficiently from the MOSFET devices to the heat sink for high performance
TOPAZ eliminates ground loop noise
*****-ANA circuitry keeps preamp signal clean
NOMAD "intelligent" protection circuitry
variable high-pass/low-pass crossover (40-400 Hz, 12 dB/octave)
variable Punch Bass boost (0-18 dB at 45 Hz) with remote
11-3/16"W x 2-7/16"H x 16-7/16"D
Infinity Reference 7541a amp - $100 shipped obo
656 Watts Max 4-Channel Amplifier
Supports remote subwoofer control
RMS Power Rating:
4 ohms: 111 watts x 4 chan.
4 ohms: 278 watts x 2 chan.
2 ohms: 139 watts x 4 chan.
RCA and speaker level inputs
Bass boost 0 - 12dB
Preamp outputs
Bridgeable
Dimensions: 12" L x 15" W x 2-11/16" H
100dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-200Hz
Maximum Input:
8Vrms
Thunder EQ:
Crossover:
Dimensions:
CEA compliant
Tri-way capable
RMS Power Rating:
Bass boost 0 - 12dB
Preamp outputs
Bridgeable
