Sold FS Mtx sony kicker kenwood audiobahn
kraudio12
First i have a Mtx Thunder 342 for sale
never been pushed hard had it powering a 10" infinity refence series in my pickup
amp has a couple scratchs but works a 100%
specs from back of amp
60 rms x2 into 4ohm
120rmsx2 into 2 ohm
240rms bridged into 4ohm
rms ratings at 12.5vdc
340 rms bridged into 4 ohm(14.4)
amp guts says
2 x 85 watts RMS @ 4 ohms
1 x 340 watts RMS bridged @ 4 ohms
price
85+shipping
Second is a Kenwood kac7201 this amp is still new i have used it for about two weeks not even pushing it used it for front door speakers.
100% working
specs
2 x 150W @ 4 ohms (20Hz ∼ 20kHz, 0.08% THD)
2 x 230W @ 2 ohms (1kHz, 0.8% THD)
1 x 460W @ 4 ohms bridged (1kHz, 0.8% THD)
Freq. Response: 5Hz ∼ 50kHz
S/N Ratio: 100dB
Current Consumption: 43A (4 ohm, 10% THD)
Fuse: 2 x 30A
Dimensions: 12" x 11.25" x 2.25" (30.5cm x 28.5cm x 5.7cm)
Weight: 7.3 lb. (3.32 kg.)
Price 100+shipping
Third is Sony Exm302 Nice little amp its a little beat up but its nice
im not gonna bud from the price so if it doesn't sell ill find away to use it in my truck
specs
Rated Outputs (supply Voltage At 14.4V):30 watts per channel (20Hz-20kHz, 0.5%THD, at 2 ohms)
# Rated Outputs (supply Voltage At 14.4V):Monaural: 90 watts per channel (20Hz-20kHz, 0.5%THD, at 4 ohms)
# Rated Outputs (supply Voltage At 14.4V):45 watts per channel (20Hz-20kHz, 0.5%THD, at 2 ohms)
price 55+shipping
Fourth thing i have for sale is a pair of 5 1/4 inch compent speakers these are brand new they still havent been broke in. Had them for just as long as the kickers the only problem with these is one of the tweets wire broke when installing and i dropped the cross over maybe a foot from the my hand to the floor of the truck and i had the wire for the tweeter in and the bottom connection of the wire broke and i just pig tailed more speaker wire to it and couldn't notice any difference
specs
5-1/4"
Design 2-way Component System
Tweeter Design Dome
Tweeter Composition Silk
Woofer Composition Carbon Honeycomb
Woofer Surround Butyl Rubber
Peak Power Handling 160 watts
RMS Power Handling 80 watts
Sensitivity 90 dB
Frequency Response 35 - 25000 Hz
Impedance (per voice coil) 4 ohms
price 45+ship
Finally i have a pair of 8" kicker L7s
They are the 08 model i have only had them for about two months haven't seen much power at all they still smell new and still 100% functioning and cosmetics
specs
8, 20.32
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 900/450
Sensitivity (dB 1w/1m) 83.6
Frequency Response (Hz) 28-100
Mounting Depth (IN.,CM) 4-3/4, 12.1
Mounting Cutout, Square (IN.,CM) 7-1/4, 18.4
Min Rec Sealed Box Volume (CU. FT., Liters) .33, 9.4
Max Rec Sealed Box Volume (CU. FT., Liters) .75, 21.2
Min Rec Vented Box Volume (CU. Ft., Liters)** .66, 18.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 1.0, 28.3
price 200+shipping
pictures of everything are at this link
http://s809.photobucket.com/albums/zz19/kraudio/
kraudio12
kraudio12
CP, Indiana
kraudio12
