Sold FS *modded* HK4000D
audioarsonal
JaMarcus
Well this needs to go to make room for more power.I have my MA Audio HK4000d for sale.It was purchased off of this forum from another member and has served me well.I ran it as a daily/comp amp at 1ohm 16v no problem.The amp does have some damage around the mounting holes as well as lite scratches on the bottom.This amp does have the protection mod so it will run lower then 2 ohms and will go down to 1/2ohm with proper electrical.I will let it go for $325 plus shipping.Pics will be up tomorrow.
Pics up for viewing....
My homeslice hooked me up wit da bomb of a sub. Sold me this Pyarmid sub on the down low for mad cheap. Will that amp handle this bad-*** sub? Do da amp put out 14ohms so I can mach it wit my output voltage of 14v from my altanader? Do I need a fuse or extra wire to set up dis sucka?
Will you take a check?
My homeslice hooked me up wit da bomb of a sub. Sold me this Pyarmid sub on the down low for mad cheap. Will that amp handle this bad-*** sub? Do da amp put out 14ohms so I can mach it wit my output voltage of 14v from my altanader? Do I need a fuse or extra wire to set up dis sucka?Will you take a check?
I think that sub will be WAYYYYYYYYYYY under powered by this amp!!!!!!!!!!!!!!!!!!!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
audioarsonal
JaMarcus
audioarsonal
close to home...
basebalz13
