I have a Memphis Mojo 2000D for sale. It is in current need of repair. It is also already at the repair house. Chris from db-r has it. Here is an email I have recieved from him regarding repair.
Here are examples of his work, specifically on the Mojo...
http://www.db-r.com/repairs/index9.html
Here are pics of the actual amp...
Here is a pic of someone elses. I'm posting this to show detail.....
RMS Power 4 ohm (Watts) 1200 x 1 @ 13.8V
RMS Power 2 ohm (Watts) 2000 x 1 @13.8V
RMS Power 2 Ohm (Watts) 2400 x 1 @ 15.5 V
Modded specs.......
RMS Power 1 Ohm (Watts) 3000+ x 1
This amp has been modded to run at 1 0hm
Sold When all is said and done you will have a like new w/ warranty Mojo for $350. Check around, that price is incredible.
Trades I will consider. Amps that are 3k+@1, or certain sub(s). Of course I will add cash.
This amp does power up so repair should be $125 plus $25 to ship back to you.they run $125to repair if the outputs or power supply is bad. They run $150 if the power supply AND outputs are both bad.
Modded specs.......
