Sold FS: Memphis Belle, Fisher box, Cadence comps, speaker rings
IonSQL
Make/Model:
Memphis Belle 16-MC1300d
Specs:
Front/Rear:
75x4 @ 4 ohms
115x4 @ 2 ohms
230x2 @ 4 ohms bridged
Sub:
300x1 @ 4 ohms
600x1 @ 2 ohms
1100x1 @ 1 ohm
HP/LP crossover, subsonic filter
6.5" x 2" x 22.5"
Condition/Description/Other Information:
Monster power in a relatively small package.
Works perfectly, had an issue with the RCA's but that has been fixed.
Cosmetically 6/10, has some scratches and a gouge on the cover, but none of it affects performance.
Comes with approx. 21 months left on a transferable SquareTrade warranty. If something happens to it, they will either get it fixed or give $$ to replace.
I do have a bridging module, but the neg wire is fried. I'm sure it could be opened up and a new wire soldered onto the board and it would work fine. If you want I could repair it after the sale.
Price (with paypal fees included):
$425 shipped
Contact Information:
PM me here or email IonSQL@yahoo.com
Shipping Information
Shipped and insured via DHL or UPS
Pics:
Make/Model:
n/a
Specs:
2.5cf @ 32Hz for 4 8" subs, 31.5 sq in of port area
Designed for 4 eD 9Kv.2's
Built from 3/4" Trupan
40"w x 17"d x 12"h
Used for about 2 weeks, subs were mounted once.
Bottom is scratched, and the back has screw holes from where the amp was mounted and where the brackets held it to the floor. None of the screw holes go all the way through.
The finish is black hammered paint, the baffles are painted blue.
Binding posts installed, and is prewired with 12 ga Knu speaker wire.
Details on the build and more pics can be seen here:
Box Build for IonSQL, PICS INSIDE!! - Car Audio Forum - CarAudio.com
$80 + actual shipping
shipped & insured via DHL
Pics:
What exactly does the bridging module do? I see the amp only has one sub input so I'm assuming it bridged the RCA inputs into a mono signal. If you had a head unit or processor that had a mono output could you just use one side of the RCA's instead of the module?
I had the same question, and finally called Memphis to talk to them about it. Here's what they told me...
The main purpose of the bridging module with a single amp is to boost the input voltage from the RCA's, and to give you the ability to change phase 180 degrees to the subs by using either the right or left output of the bridging module.
It provides a summed mono signal to the amp.
It CAN be used without it. The front & back channels will distribute signal to the sub channel if the input on the sub RCA is not present. Basically, you don't need it.
The downfall to not using it is that the input voltage is lower (meaning, for a specific gain setting for the sub channel, output will be less if the module is not used. Without the module, the gain just needs to be set a bit higher to achieve the same output.), and you will not have sub control from the head unit.
Long answer, but in essence, it is not required, but is useful for greater control.
As long as you have a head unit or processor that can provide a true summed mono signal, you should be OK.
IonSQL
IonSQL
Aviston, IL
gl0ck
