Sold FS: Memphis 16-MCD1500 - $325 OBO
sundownz
Pro Seller
Supporting Vendor
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
# Class D Monoblock Subwoofer Amplifier
# Compact Aluminum Chassis with Custon Black Pearl Finish
# RCA Outputs: 1 Pair
# Gold Plated RCA Connectors
# Full MOSFET Design
# Built-In Fully Variable Low Pass Filter: 50 - 250 Hz
# 18dB Per Octave Crossover Slope
# Built In Fully Variable Sub-Sonic Filter: 20 - 50 Hz
# Platinum Finish Wire Connections
# Accepts 4 Gauge Power and Ground Wire
# Optional Wired Remote Gain Control
# RMS Power Ratings:
* 750 watts x 1 chan. @ 4 ohms
* 1500 watts x 1 chan. @ 2 ohms
# Adjustable Input Sensitivity: 200mV - 4V
# Dimensions: 21.26" L x 7.6" W x 2.4" H
See Original Post.
"This amplifier has been tested on the bench to operate normally..."
He asked if I "bench" aka: power tested the amp - which I did not. I just tested it to make sure it works - but did not perform detailed tests.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
