Sold FS: McIntosh MCC302
genxx
Team JL Audio
I took a trade on this from someone else. I have no use for it and has been sitting on my shelf for 6 months. I would love to keep it but my shelves are full and my play money is low. I tested it and it works great.
The glass top is flawless and the amp condition is 8.5-9 out of 10. It is in really great condition.
I would like to get $375 shipped and insured. I am open to best offers on this as I need to finance a new project.
Quick info:
Power Output Per Channel
150 watts into 4 ohm loads and 300 watts into 2 ohm loads is the minimum sine wave continuous average power output per channel, with both channels operating.
Power Output Bridged
600 watts into 4 ohm loads is the minimum sine wave continuous average power output.
Rated Power Band
20Hz to 20,000Hz
Total Harmonic Distortion
Maximum Total Harmonic Distortion at any power level from 250 milliwatts to rated power output is:
0.005% for 4 ohm loads
0.008% for 2 ohm loads
0.008% for Bridged Mode with 4 ohm loads
A-Weighted Signal To Noise Ratio
105dB (1.5V)
One Band Equalizer
Center Frequency is variable from 40Hz to 2,000Hz, level variable ±12db, Q fixed at 2
Crossover
Selectable High pass or Low pass. The frequency is variable from 50Hz to 120Hz. The slope is 12dB per octave (Low pass is 24dB per octave in bridged mode)
Subwoofer Output
Low Pass filtered at 200Hz with a 6db per octave slope(level variable ±12db when using optional McIntosh External Subwoofer Rotary Control)
Dimensions
12.5 inches (31.8cm) wide, 3.0 inches (7.6cm) high, 13.7 inches (34.8cm) depth
Here is a link to all the info on it.
McIntosh | MCC302
genxx
Team JL Audio
genxx
Oklahoma
stevexyz
