MB QUART Reference RAA4200
» 4-channel car amplifier
» 100 watts RMS x 4 at 4 ohms (200 watts x 4 at 2 ohms)
» 400 watts RMS x 2 in bridged mode (4-ohm minimum impedance)
» CEA-2006 compliant
» front and rear high- and low-pass filters (variable 50-500 Hz at 12 dB per octave)
» multiplier x10 switch converts filters to variable from 500 to 5,000 Hz
» LED clipping indicators
» preamp-level inputs and outputs
» front end defeat bypasses gain and crossover controls
» fuse rating: 30A x 3
» requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
» 11-1/2"W x 2-3/8"H x 16-3/4"
It is in excellent functional and cosmetic condition. The only thing that is wrong with the amplifier is that it is missing 3 small screws. one set screw for one of the speaker plugs. It is also missing a screw from the bottom cover and one from the end cap.
$265 shipped (fees/insure included)
