FS: MB Quart DSC2000
Mitch86
Mb quart discus 2k
The last time I had this amp installed it had problem I thought were due to a bad ground. Ended up selling it and it had the same problem in the buyers install so I refunded and got the amp back. I opened it up and found nothing burned or out of place. Recently took the board completely out and found a bad solder spot on one of the metal "rails" that go through the board. I soldered it back up but haven't tested it as I have no sub to test with.
100 shipped firm. Sold as-is !!!!!!!SEE DESCRIPTION!!!!! This amp may work fine! Also may still have the problem I was having...but I was told it could be repaired for less than 100 bucks.
I pay shipping
Item Pictures: pics up in a few
The issue was it "surged" in power even with volume at 0. To me it really seemed like a ground issue.. but upon inspecting tthe bottom of the board, I found the bad solder spot and also underneath that there was signs of "arcing" on the case... its possible that soldering up that spot fixed the problem, but may be not.
Ill consider trades guys, just shoot me PMs with what ya got!
Mitch86
Mitch86
Tennessee
pro-rabbit
